TO SETUP DERIVED PART DIALOG BOX SETTINGS
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
I frequently have to create derived parts at skeleton modelling.
Could some one provide me with a rule so that derived part dialog box made to appear as shown below.
ALSO USE COLOR OVERRIDE FROM SOURCE COMPONENT TICKED OFF.
Thanks a lot for the help.
JaneFan
Hey @RoyWickrama_RWEI ,
Here is the iLogic rule to do so:
Dim oPD As PartComponentDefinition
oPD = ThisDoc.Document.ComponentDefinition
Dim DD As DerivedPartDefinition
DD = oPD.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef("Full path of derived part")
DD.ExcludeAll()
DD.UseColorOverridesFromSource = fasle
Dim oPDC As DerivedPartComponent
oPDC = oPD.ReferenceComponents.DerivedPartComponents.Add(DD)
Jane Fan
Inventor/Fusion QA Engineer
RoyWickrama_RWEI
Hi Jane;
It is a good code.
I revised it as follows.
I have the full document name copied in the clip board as a result of running another code. It works. My only concern is I need the Derived Part dialog box remains open so that I can turn on the required variables or work features.
Could you fix it, please. Thanks.
Imports System.Windows.Forms
Sub main()
'DD = oPD.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef("Full path of derived part")
oDoc_Source = Clipboard.GetText()
DD = oPD.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oDoc_Source)
DD.ExcludeAll()
End Sub
