Titelblock - symbols
Message 1 of 12
I am creating a new idw template.
I need to show a small table at the upper right hand side of the template...
when cycling through different sheet sizes.. A1, A2 etc.. then the table/symbol should move accordingly so that it is in the upper right hand side..
has anyone done anything like this using ilogic?
Replies (11)
Message 2 of 12
Curtis_Waguespack
Hi lynlaysaymo,
Here is a quick example, as well as an attached 2017 file. In the attached file, the code handles the offset for a border as well.
I hope this helps.
Curtis
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
For Each oSymbol As SketchedSymbol In oSheet.SketchedSymbols
	If oSymbol.Name = "My Table" Then
		Dim oPoint As Point2d = oSymbol.Position
		oPoint.X = oSheet.Width
		oPoint.Y = oSheet.Height
		oSymbol.Position = oPoint
Next
Message 3 of 12
salariua
@Anonymous If it's a table (not a symbol) then you need to calculate table width, length.
I have just been playing with this and tables are attached from the top left corner from what I can see (or at least revision table is).
Nonetheless, the Maestro is on the case and gave you nice and clean answer.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 4 of 12
this works great; thanks!
 I simply changed
oPoint.X = oSheet.Width - 3.234
oPoint.Y = oSheet.Height - 2.3242
etc...
now :)... how about for placing something on the upper right hand side of the drawing... ? same applies if the sheet size changes then  I need to the symbol to move accordingly.
thanks all...
Message 5 of 12
sorry... not the upper right but the upper left now... apologies for the confusion
Message 6 of 12
salariua
I don't see a way of getting symbol size and the values might be different for you
		oPoint.X = 0 + 3.234
Next
Adrian S.
blog.ads-sol.com
Message 7 of 12
perfect, thank you!!
Message 8 of 12
Mecanico14
Good afternoon.
Can the A4 format be turned 90 °?
The others interest me in horizontal, but the vertical A4.
An alternative would be to be able to select the presentation between horizontal and vertical, as you can choose when printing, for example.
Excellent work.
(Sorry for my English, I use a translator).
Thank you.
Un saludo.
Mecanico14
Siempre parece imposible hasta que se hace.
Message 9 of 12
salariua
this works out of the box and it's quite user-friendly?
Adrian S.
blog.ads-sol.com
Message 10 of 12
Mecanico14
Thanks for answering.
Yes, I know it can be done outside the box, but I wanted to be able to select it from the box. Or at least the A4 format is positioned vertically, as is normal in the Standard.
It is not a problem to select it from the outside, simply that by creating such a simple way to change the format, it seemed more correct to at least see the A4 vertically.
Thanks again for helping.
(Sorry for my English, I use a translator.)
Un saludo.
Mecanico14
Message 11 of 12
salariua
If oSheet.Size = Inventor.DrawingSheetSizeEnum.kA4DrawingSheetSize Then
	oSheet.Orientation = Inventor.PageOrientationTypeEnum.kPortraitPageOrientation
Else
	oSheet.Orientation = Inventor.PageOrientationTypeEnum.kLandscapePageOrientation
Adrian S.
blog.ads-sol.com
Message 12 of 12
Mecanico14
Wonderful, awesome, perfect, is what I needed.
In case anyone is interested:
In the example provided by @Curtis_Waguespack, there are three rules of iLogic, I was not sure where to put this code and I added it in the first rule "Move Symbol", thus:
'define border offset adjustment value
oBorderWidth = 0.325 * 2.54 '2.54 converts value to inches
Else
		oPoint.X = oSheet.Width - oBorderWidth
		oPoint.Y = oSheet.Height - oBorderWidth
Next
Thank you very much @salariua
Un saludo.
Mecanico14
