ThisDoc.Document is not defined error
j3scat
j3scat
I am trying to create a rule that uses ThisDoc.Document
A.Acheson has been helping me troubleshoot my rule here ->https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/link-excel-file-to-parameters-via-fi...
But I think the error I am dealing with is external to my initial question
I am unable to
Dim xDoc As ThisDoc.Document
 or i get a 'ThisDoc.Document is undefined' when i attempt to run the rule.  Within the last month I had a number of rules break and I have been continually messing with 'ActiveDocument'/'ActiveEditDocument' to fix the issue, but I currently can't use ThisDoc.Document on an External or an Internal Ilogic Rule.
I am not attempting to run a VB.net routine. This is through the inventor rule editor. ( I do have rubber duck installed)
J-Camper
@j3scat,
You are combining the task of defining and casting an object to an objectvariable. Do this:
Dim xDoc As Document =  ThisDoc.Document
This also works, but I would recommend the former:
xDoc =  ThisDoc.Document
 Also since it is a local rule, you could be more specific with the document type:
Dim aDoc As AssemblyDocument =  ThisDoc.Document
     'or
Dim pDoc As PartDocument =  ThisDoc.Document
     'or
Dim dDoc As DrawingDocument =  ThisDoc.Document
j3scat
Sigh, yes you are right.
I'm getting tired and not seeing things correctly.
(applying your correction does not fix my initial issue however. Hopefully a rest and restart tomorrow will see something equally obvious)
BTW, nice description. I wish I had found something this simple and straightforward months (years?) ago.
