`ThisApplication` within `AddVbFile` file
I'm trying to access `ThisApplication` from within a file accessed by a rule through `AddVbFile`
I'm sure there's a very good reason for this not working, but I don't know what it is. I imagine it has something to do with what's known at compile time vs. what's known at runtime.
Does anyone know what it might be?
Michael.Navara
AddVbFile merges code from this file to your main rule. But in this rule, you can't use any iLogic enhancements like ThisApplication or ThisDoc. Usually I use this for for code enclosed in class and in main rule I can create instance of this class and I need to pass all relevant references to this class (usually in constructor).
MyExternalVbCodeClass.iLogicVb code:
Class MyExternalVbCodeClass
	'You can rename this to ThisApplication
	Dim ThisApplicationInMyClass As Inventor.Application
	Public Sub New(inventorApp As Inventor.Application)
		Me.ThisApplicationInMyClass = inventorApp
	End Sub
	Public Function GetCaption() As String
		Return ThisApplicationInMyClass.Caption
	End Function
End Class
Main rule
AddVbFile "C:\Path\To\MyExternalVbCodeClass.iLogicVb"
Dim myExternalVbCodeClassInstance = New MyExternalVbCodeClass(ThisApplication)
Logger.Debug(myExternalVbCodeClassInstance.GetCaption())
Yeah, that's a nice idea. Thanks
