ThisApplication.OpenDocumentsDisplay
mikazakov
mikazakov
What does object ThisApplication.OpenDocumentsDisplay?
I did not see its effect.
Curtis_Waguespack
Hi mikazakov,
As far as I can tell, it controls the recent documents list:
I used this code to toggle it (using iLogic):
If ThisApplication.OpenDocumentsDisplay = True Then
ThisApplication.OpenDocumentsDisplay = False
Else
End If
I hope this helps.
Curtis
MechMachineMan
Just a quick little tidbit.
I'm reading a book called Becoming a better programmer, but am not a programmer.
It suggests avoiding redundancy and keeping things simple and free of loops if possible, so to do a toggle for a boolean property, it suggests using:
ThisApplication.OpenDocumentsDisplay = Not ThisApplication.OpenDocumentsDisplay
It also creates less lines of code which means less to debug in the future!
Best of luck in your code escapades!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Curtis_Waguespack
Thanks for the tip, Justin!
I just ordered that book (based on your recommendation), so hopefully it'll help me break some bad habits, no promises though. Smiley Wink
