Thicken feature in Sheet metal
piotrekdoro94
piotrekdoro94
Hi, I'm using Inventor 2016 and I'm trying to create a vba form that would generate YConnectors. I've managed to draw the shape of the YConnector with surface bodies but I can't thicken them. Thera are three thicken features present (on lines 39, 43, 47) but only the first one of these will work. If I comment out thicken feature on line 39 then  the thicken command on line 43 will work, but the one on line 47 won't
Below there is a relevant code snippet:
Imports Inventor
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim InventorApp As Inventor.Application
        Try
            InventorApp = Marshal.GetActiveObject("Inventor.Application")
            MessageBox.Show("Connected To Inventor session")
        Catch ex As Exception
            MessageBox.Show("Failed to connect to inventor session")
        End Try
        If Not (InventorApp.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then 'Switch document subtype to sheet metal
        Dim oPartDoc As PartDocument
        Dim oPartCompDef As SheetMetalComponentDefinition
        'Dim oPartCompDef As ComponentDefinition
        oPartDoc = InventorApp.ActiveDocument
        oPartCompDef = oPartDoc.ComponentDefinition
        Dim oThickenCollectorFaceCollection As FaceCollection
        Dim oThickenInletFaceCollection1 As FaceCollection
        Dim oThickenInletFaceCollection2 As FaceCollection
        Dim oThickenCollector As ThickenFeature
        Dim oThickenInlet1 As ThickenFeature
        Dim oThickenInlet2 As ThickenFeature
        oThickenCollectorFaceCollection = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
        oThickenCollectorFaceCollection.Add(oPartCompDef.Features(1).SurfaceBodies(1).Faces(1)) 'Add collector surface to face collection
        oThickenCollector = oPartCompDef.Features.ThickenFeatures.Add(oThickenCollectorFaceCollection, Convert.ToDouble(CollectorThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken collector
        oThickenInletFaceCollection1 = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
        oThickenInletFaceCollection1.Add(oPartCompDef.Features(2).SurfaceBodies(1).Faces(1)) 'Add inlet 1 surface to face collection
        oThickenInlet1 = oPartCompDef.Features.ThickenFeatures.Add(oThickenInletFaceCollection1, Convert.ToDouble(InletThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken inlet 1
        oThickenInletFaceCollection2 = InventorApp.TransientObjects.CreateFaceCollection() 'Create face collection
        oThickenInletFaceCollection2.Add(oPartCompDef.Features(3).SurfaceBodies(1).Faces(1)) 'Add inlet 1 surface to face collection
        oThickenInlet2 = oPartCompDef.Features.ThickenFeatures.Add(oThickenInletFaceCollection2, Convert.ToDouble(InletThicknessTextBox.Text) / 10, PartFeatureExtentDirectionEnum.kPositiveExtentDirection, PartFeatureOperationEnum.kNewBodyOperation) 'Thicken inlet 2
        oPartDoc.Update()
    End Sub
End Class
And a model it should work on:
I suspect that there is a problem with the way I'm using sheet metal environment because if I switch to normal part environment it works:
Imports Inventor
Public Class Form1
        Try
        End Try
        oPartDoc.Update()
    End Sub
End Class
nstevelmans
hi, run your solution test.zip works all fine  (inventor 2024), maybe it is the version of inventor
piotrekdoro94
I've managed to  solve it for now but I have to keep switching document's substyle from general part to sheet metal part and back.
