There is a way to create ballons lines parallels to others lines?
abrahambarroeta
abrahambarroeta
I am looking for a way to create lines like these (by simply adding a point to the balloon line) and create something similar to the picture.
Any ideas?
The thing is, I want to create balloons, and the balloon lines should run parallel to certain reference lines.
WCrihfield
Hi @abrahambarroeta.  What you are asking for may be possible to some degree, but it will be pretty complicated to achieve by custom code, and the results will not be constrained.  For one thing, you can't just get the angle of the line, then set that angle to the other line...it's way more complicated than that.  We are dealing with a bunch of Point2d, Vector2d, and UnitVector2d objects.  A Vector2d has both direction and magnitude (length), but do not provide a direct property for what angle they are from some imaginary fixed line.  The 'direction' of the vector is determined by passing an imaginary line from a 0,0 coordinate through the X & Y coordinates it provides, which can be difficult to picture in your mind.  And since view line you pick has a direction, not just an angle, that direction may be pointing in the opposite direction than you expect, which potentially has to be corrected later in the code.  Another complication of this process is that we have to specify coordinates for where to place the node on the sheet, which is often a matter of personal preference and style.  This code just tries to create a new node half way between the two existing nodes, then move that node to a position that makes the visible line look parallel with the view line, while leaving the balloon in place.
I have an iLogic rule you can try out for this task, and develop further if you want.  When ran, it first asks you to select a straight drawing view line to use for aligning the balloon leader with.  Then it asks you to select a Balloon (can't select just its leader or a leader segment) that you want to align with that line.  There is a lot of code in there, and it could likely be done more efficiently, but it seemed to be working OK in my testing.
'<<< Drawing Curve section >>>
Dim sPrompt As String = "Select a straight drawing view line to align balloon leader with."
Dim oFilter As SelectionFilterEnum = SelectionFilterEnum.kDrawingCurveSegmentFilter
Dim oDCS As DrawingCurveSegment = ThisApplication.CommandManager.Pick(oFilter, sPrompt)
If oDCS Is Nothing Then Exit Sub
Dim oLineDir As UnitVector2d = Nothing
Dim bLineDirXPositive As Boolean = False
Dim bLineDirYPositive As Boolean = False
If oDCS.GeometryType = Curve2dTypeEnum.kLineCurve2d Then
	Dim oL2D As Line2d = oDCS.Geometry
	oLineDir = oL2D.Direction
	bLineDirXPositive = (oLineDir.X > 0)
	bLineDirYPositive = (oLineDir.Y > 0)
ElseIf oDCS.GeometryType = Curve2dTypeEnum.kLineSegmentCurve2d Then
	Dim oLS2D As LineSegment2d = oDCS.Geometry
	oLineDir = oLS2D.Direction
Else
	MsgBox("Selected Geometry Is Not A Straight Line", , "")
	Exit Sub
Logger.Info("Line Direction Is Positive? = " & bLineDirXPositive & vbCrLf & _
"Direction Coordinates = " & oLineDir.X & " , " & oLineDir.Y)
' <<< Balloon section >>>
sPrompt = "Select a Balloon to allign."
oFilter = SelectionFilterEnum.kDrawingBalloonFilter
Dim oBalloon As Inventor.Balloon = ThisApplication.CommandManager.Pick(oFilter, sPrompt)
If oBalloon Is Nothing Then Exit Sub
Dim oLeader As Inventor.Leader = oBalloon.Leader
If oLeader.HasRootNode = False Then Exit Sub
Logger.Info("HasRootNode = True")
Dim oRootNode As LeaderNode = oLeader.RootNode
Logger.Info("RootNode Position = " & oRootNode.Position.X & " , " & oRootNode.Position.Y)
Dim oNodes As LeaderNodesEnumerator = oLeader.AllNodes
If oNodes.Count < 2 Then Exit Sub
Dim oLastNode As LeaderNode = oNodes.Item(oNodes.Count)
Logger.Info("Last Node Position = " & oLastNode.Position.X & " , " & oLastNode.Position.Y)
Dim oNextNode As LeaderNode = oNodes.Item(oNodes.Count - 1)
Logger.Info("Next Node Position = " & oNextNode.Position.X & " , " & oNextNode.Position.Y)
Dim oV2D As Vector2d = oLastNode.Position.VectorTo(oNextNode.Position)
Dim oNodesDir As UnitVector2d = oV2D.AsUnitVector
Dim bNodesDirXPositive As Boolean = (oNodesDir.X > 0)
Dim bNodesDirYPositive As Boolean = (oNodesDir.Y > 0)
Logger.Info("Nodes Direction Is Positive? = " & bNodesDirXPositive & vbCrLf & _
"Direction Coordinates = " & oNodesDir.X & " , " & oNodesDir.Y)
If oNodesDir.IsParallelTo(oLineDir) Then Exit Sub
'<<< create new node half way between these two existing nodes >>>
Dim oNewP2D As Point2d = oLastNode.Position.Copy
oV2D.ScaleBy(0.5)
oNewP2D.TranslateBy(oV2D)
Dim oNewNode As LeaderNode = oRootNode.InsertNode(oLastNode, oNewP2D)
'<<< compare direction of view line and direction between nodes >>>
'<<< may need to do some math here to determine if directions need to be flipped >>>
Dim bBothXPos, bBothYPos, bBothXNeg, bBothYNeg, bXDiff, bYDiff As Boolean 'False by default
If bLineDirXPositive And bNodesDirXPositive Then
	bBothXPos = True
ElseIf bLineDirXPositive = False And bNodesDirXPositive = False Then
	bBothXNeg = True
Else
	bXDiff = True
If bLineDirYPositive And bNodesDirYPositive Then
	bBothYPos = True
ElseIf bLineDirYPositive = False And bNodesDirYPositive = False Then
	bBothYNeg = True
Else
	bYDiff = True
Dim oFinalP2D As Point2d = oLastNode.Position.Copy
If bBothXPos And bBothYPos Then
ElseIf bBothXNeg And bBothYNeg Then
ElseIf bXDiff And bYDiff Then 'when directions may need to be flipped
	oLineDir.X = (oLineDir.X * -1) 'toggle between positive or negative
	oLineDir.Y = (oLineDir.Y * -1) 'toggle between positive or negative
Dim oFinalV2D As Vector2d = oLineDir.AsVector
oFinalV2D.ScaleBy(oLastNode.Position.DistanceTo(oNewNode.Position))
oFinalP2D.TranslateBy(oFinalV2D)
oNewNode.Position = oFinalP2D
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
abrahambarroeta
Thanks for the reply!
It works great, but if I have two points into the ballon, the ilogic rule just allign the first segment.. Is there an option for make the same for all the segment?
the script only aligns the first segmentthe script only aligns the first segment
Any idea?
