The location of the text on the dimension line.
jarle_oudalstoelEN4BR
Hi everyone.
I'm working on some automation for dimensioning a drawing.
The issue I'm having is when the dimension lines are close together I would like to move the text to the right or left side.
In the image above I would like move the 12 to the right side of the arrows.
This is the code line I am currently using to place this dimension
SP01 = oView.GetIntent({SUBASS, SUBASS2, oPart},"FRONT RIGHT 1")
LDIMNUMBER = LDIMNUMBER + 1
oLinDim = oGenDims.AddLinear(LDIMNAME & LDIMNUMBER, oView.SheetPoint(0.0, -0.1), SP01, , , , , oNewStyle02)
 I would also like to move the 2 dimension above the respective arrows.
All help would be greatly appreciated.
Best regards Jarle
Stakin
oLinDim.text.HorizontalJustification=Inventor.HorizontalTextAlignmentEnum.kAlignTextRight
Hi Stakin.
I appreciate the response. I did add that line to my code but unfortunately I'm getting an error message.
The error is as shown below.
Maybe you can help me with what I'm not doing in my code?
Stakin
oLinDim.NativeEntity.text.HorizontalJustification=Inventor.HorizontalTextAlignmentEnum.kAlignTextRight
Hi Stakin.
I really appreciate your input on my issue.
The code line you provided will make the text justification right oriented in the text window in the Edit Dimension dialog box. That is very valuable for me to know so I do appreciate the knowledge you shared. unordinary it does not solve my problem.
Now this all might be my poor explanation of my issue.
When I use iLogic to place my dimension it puts the number in the middle of the line as shown by the red circle (1)
What I would like to do is force it to the right side as shown in the green circle (2)
