The first refresh IDW ilogic script that works (fixes graphical display bugs)
maxim.teleguz
maxim.teleguz
Because i am constantly trying to improve inventor sometimes i need to reinstall the software to get back to square one, but some work policies might not allow that.
this is my ilogic script that i use to refresh any graphical issues in drawings.
'Definitions
Dim p As DrawingDocument = ThisApplication.ActiveDocument
Dim s As Sheet = p.ActiveSheet
Dim oDV As DrawingView
Dim oSketch As DrawingSketch
Dim oDC As DrawingCurve
'Loop through all views that currently exist on the active sheet
For Each oDV In s.DrawingViews
       'Create a new sketch on the active view
	oSketch = oDV.Sketches.Add
	'Put the sketch in edit mode
	oSketch.Edit
	'Exit the sketch
	oSketch.ExitEdit
	oSketch.Delete
Next
maxim.teleguz
the way sketch creation and exiting out of sketch works restores the drawings graphical display really well. that means the autodesk did design a graphical refresh but never made it a feature but instead added to the ends of certain commands.
This method of sketch creation and deletion work really well for being a refresh command.
WCrihfield
Hi @maxim.teleguz.  Just checking, but did you try Sheet.Update, executing the "AppRefineAppearanceCmd" command (CommandDefinition.Execute), or toggling the DrawingView.IsRasterView property's value (works similar to Right-Click Make View Raster & Make View Accurate), in your trial testing?
Wesley Crihfield
(Not an Autodesk Employee)
maxim.teleguz
I tried Raster View but then that doesn't work as the borders would still have the graphical issues and only the view would be corrected.
I did try every possible update method there is known in the ilogic work and nothing was working.
I will test the AppRefineAppearanceCmd and let you know if that works.
maxim.teleguz
AppRefineAppearanceCmd did not have any affect, however removing the last update did and i no longer have graphical issues. 2022.4.1 caused all the issues for me.
