the conversion of string to type integer is not valid
Dear everyone,
I  am trying to run a code to make a drawing of a model.
when I add a string which contains the template I want to use it gives me this error that it can not convert the string to a type integer.
since I  am a beginner in ilogic an the api, I do not understand what this error means and how to resolve it.
this is the information the error comes with:
System.InvalidCastException: De conversie van tekenreeks P:\2_ENGINEERING\PROJ-2020\P20-0 naar type Integer is ongeldig. ---> System.FormatException: Input string was not in a correct format.
at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
--- End of inner exception stack trace ---
at ThisRule.CreateDrawing(Application& m_inventorApp)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
this is the code I am trying to run:
 	Sub Main
	CreateDrawing(ThisApplication)
End Sub
Public Sub CreateDrawing(ByRef m_inventorApp As Inventor.Application)
	' Create a new drawing document using the default template.
	Dim oDrawDoc As DrawingDocument
	oDrawDoc = m_inventorApp.Documents.Add("P:\2_ENGINEERING\PROJ-2020\P20-050-SFTOM\02_Support frame Lennart\2-ENG\2-DWG\1-INV\3-LEARNING\API leren\Template\PPV Standaart Template 2019.idw", DocumentTypeEnum.kDrawingDocumentObject, m_inventorApp.FileManager.GetTemplateFile(DocumentTypeEnum.kDrawingDocumentObject))
	Dim oSheet As Sheet
	oSheet = oDrawDoc.ActiveSheet
	' Open the part to be inserted into the drawing.
	Dim oPartDoc As PartDocument
	oPartDoc = m_inventorApp.Documents.Open("P:\2_ENGINEERING\PROJ-2020\P20-050-SFTOM\02_Support frame Lennart\2-ENG\2-DWG\1-INV\3-LEARNING\API leren\intro naar api\IntroCube.ipt", False)
	Dim oTG As TransientGeometry
	oTG = m_inventorApp.TransientGeometry
	MsgBox("Create base and orthographic views.")
	' Place the base front view.
	Dim oFrontView As DrawingView
	oFrontView = oSheet.DrawingViews.AddBaseView( _
	oPartDoc, _
	oTG.CreatePoint2d(30, 15), _
	3, _
	ViewOrientationTypeEnum.kFrontViewOrientation, _
	DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
	' Create the top, right and iso views.
	Dim oTopView As DrawingView
	oTopView = oSheet.DrawingViews.AddProjectedView( _
	oFrontView, _
	oTG.CreatePoint2d(30, 40), _
	DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	Dim oIsoView As DrawingView
	oIsoView = oSheet.DrawingViews.AddProjectedView( _
	oFrontView, _
	oTG.CreatePoint2d(75, 40), _
	DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
	MsgBox("Create detail view.")
	' Create the detail view.
	'De eerste  x-y coördinaat plaatst het aanzicht van de detail view.
	'De twee coördinaten daarna plaatsen het venster over de baseview waar een detail van getekend wordt.
	Dim oDetailView As DetailDrawingView
	oDetailView = oSheet.DrawingViews.AddDetailView( _
	oFrontView, _
	oTG.CreatePoint2d(20, 20), _
	DrawingViewStyleEnum.kFromBaseDrawingViewStyle, _
	False, _
	oTG.CreatePoint2d(33, 17.5), _
	oTG.CreatePoint2d(38, 22.5), , 4, , "A")
MsgBox("Create dimensions to the curves in the view.")
' Get the various edges of the model.
	Dim aoEdges(0 To 😎 As Edge
	Dim i As Integer
	For i = 0 To 8
		oObjs = oPartDoc.AttributeManager.FindObjects( _
		"Name", "Name", "Edge" & i)
		aoEdges(i) = oObjs.Item(1)
	Next
	' Get the equivalent drawing curves in the base view.
	Dim aoDrawCurves(0 To 😎 As DrawingCurve
	For i = 0 To 4
		oDrawViewCurves = oFrontView.DrawingCurves(aoEdges(i))
		aoDrawCurves(i) = oDrawViewCurves.Item(1)
	Next
	' Create some dimensions in the base view
	Dim oGeneralDims As GeneralDimensions
	oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
	Dim oDim As GeneralDimension
	oDim = oGeneralDims.AddLinear( _
	oTG.CreatePoint2d(32, 15), _
	oSheet.CreateGeometryIntent(aoDrawCurves(1)), _
	oSheet.CreateGeometryIntent(aoDrawCurves(3)), _
	DimensionTypeEnum.kVerticalDimensionType)
	oDim = oGeneralDims.AddRadius( _
	oTG.CreatePoint2d(38, 30), _
	oSheet.CreateGeometryIntent(aoDrawCurves(4)))
	oDim = oGeneralDims.AddDiameter( _
	oTG.CreatePoint2d(27, 18), _
	oSheet.CreateGeometryIntent(aoDrawCurves(2)), _
	True, False)
'get the equivalent edges for the top view
	For i = 5 To 8
		oDrawViewCurves = oTopView.DrawingCurves(aoEdges(i))
	Next
' Create the dimensions
	oTG.CreatePoint2d(38, 38), _
	oSheet.CreateGeometryIntent(aoDrawCurves(5)), _
	oSheet.CreateGeometryIntent(aoDrawCurves(6)), _
	oTG.CreatePoint2d(32, 45), _
	oSheet.CreateGeometryIntent(aoDrawCurves(7)), _
	oSheet.CreateGeometryIntent(aoDrawCurves(8)), _
	DimensionTypeEnum.kHorizontalDimensionType)
	MsgBox("Create a text box with a leader.")
	' Place a text box with a leader.
	Dim oObjColl As ObjectCollection
	oObjColl = m_inventorApp.TransientObjects.CreateObjectCollection
	Call oObjColl.Add(oTG.CreatePoint2d(17.5, 11))
	Dim oEval As Curve2dEvaluator
	oEval = aoDrawCurves(0).Evaluator2D
	Dim adParams(0) As Double
	adParams(0) = 0.6
	Dim adPoints(0 To 1) As Double
	Call oEval.GetPointAtParam(adParams, adPoints)
	Call oObjColl.Add(oTG.CreatePoint2d(adPoints(0), adPoints(1)))
	Dim oLeaderNote As LeaderNote
	oLeaderNote = oSheet.DrawingNotes.LeaderNotes.Add( _
	oObjColl, "Text with a leader")
	oLeaderNote.DimensionStyle = oLeaderNote.DimensionStyle
End Sub
Can someone please explain to me what is happening and how i can resolve it?
Thank you in Advance,
Lennart
JhoelForshav
@Anonymous
The arguments for Documents.Add are:
Documents.Add(DocumentType As DocumentTypeEnum, Optional TemplateFileName As String, Optional CreateVisible As Boolean)
You have these mixed up in your code, with a string value as the first argument that should be DocumentTypeEnum (=Integer). Try changing the line for creating the document to this:
oDrawDoc = m_inventorApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, _
"P:\2_ENGINEERING\PROJ-2020\P20-050-SFTOM\02_Support frame Lennart\2-ENG\2-DWG\1-INV\3-LEARNING\API leren\Template\PPV Standaart Template 2019.idw", _
True)
Thank you once again @JhoelForshav,
I keep running into these basic issues.
Do you have a recommendation were I can learn this type of stuff?
Kind regards,
Lennart
JhoelForshav
@Anonymous
The API reference manual is a good place to find information:
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-66A32241-D9C0-4E9D-B6D1-F4A9DA1F69F9
Also, if you write the functions in iLogic the intellisense should kick in:
WCrihfield
I saw a couple of other issues within that code too.
There were a couple of places where you were initializing a specific sized array.  And in those definitions you specified a start Integer for the array, but not the second (end) Integer for the array's size, before specifying its object type.
Here are the two snippets I have corrected within your first posted code:
'<<<<<<<<<<<   !!!   I ADDED THE 8 AND THE CLOSING ")" SYMBOL   !!!   >>>>>>>>>>>>>
	Dim aoEdges(0 To 8 ) As Edge
	Dim i As Integer
	For i = 0 To 8
		oObjs = oPartDoc.AttributeManager.FindObjects("Name", "Name", "Edge" & i)
	Next
Then there was this instance:
	'<<<<<<<<<<<   !!!   I ADDED THE 4 AND THE CLOSING ")" SYMBOL   !!!   >>>>>>>>>>>>>
	Dim aoDrawCurves(0 To 4) As DrawingCurve
	For i = 0 To 4
	Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Something weird is happening.  I tried correcting my last post twice, and both times, it was correct when I posted, but after it posted, it changed the character "8" into either Nothing or the Imoji (smiling face with sunglasses) character.  Very annoying.  I had to put a space between the "8" and the ")" characters to keep it from being transformed into the Imoji.
Wesley Crihfield
thank you @WCrihfield !
it seems that some things went missing after i copied my code. Its in there
