that wrong with this code ?
Darkforce_the_ilogic_guy
Advisor Advisor
dim stk
Dim docPropertySet3 As PropertySet
docPropertySet3 = rDoc.PropertySets.Item("User Defined Properties")
docPropertySet3.Item("QTY").Value
 That anyone tell me why this code fail... This is not all the code ..  it is a part of a very large complex code but the code work before I wantet to have som nummber on each partnummer export to a excel list.
I simple list want to add the QTY to the date. but as soon as I add the code it fail
I am getting this error
fullevent
Hi @Darkforce_the_ilogic_guy,
what are you trying with the last line? To read or to write?
Maybe you wanted this?
stk = docPropertySet3.Item("QTY").Value
 Also stk as Integer?
Maybe it's just something small like that.
Best regards,
Aleksandar Krstic
Produkt- und Projektmanager
I end up using
	stk = brow.ItemQuantity
I remove the as Integer. as I was not use if it would be an string or Integer . So that was never the problem
