Textbox
Textbox
andrew_basket05
Textbox
andrew_basket05
Hi guys,
I have a flatpattern on witch I created a sketch with all the edges and bends project. Here's my code:
Dim partDoc As Document
Set partDoc = ThisApplication.ActiveDocument
Dim UOM As UnitsOfMeasure
Dim eLengthUnits As UnitsTypeEnum
Set UOM = partDoc.UnitsOfMeasure
eLengthUnits = UOM.LengthUnits
Dim partDef As SheetMetalComponentDefinition
Set partDef = partDoc.ComponentDefinition
If partDef.FlatPattern Is Nothing Then
partDef.Unfold
Dim partflat As FlatPattern
Set partflat = partDef.FlatPattern
Set sk = partflat.Sketches.Add(partflat.TopFace, True)
sk.Name = "CTS"
sk.Edit
Dim i As Integer
For i = 1 To sk.SketchEntities.Count
sk.SketchEntities(i).Construction = False
Next
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oRB As Box2d
Set oRB = oTG.CreateBox2d
Dim oEnt As SketchEntity
For Each oEnt In sk.SketchEntities
Call oRB.Extend(oEnt.RangeBox.MinPoint)
Call oRB.Extend(oEnt.RangeBox.MaxPoint)
Next
Set minXminY = oTG.CreatePoint2d(oRB.MinPoint.X, oRB.MinPoint.Y)
Set minXmaxY = oTG.CreatePoint2d(oRB.MinPoint.X, oRB.MaxPoint.Y)
Set maxXminY = oTG.CreatePoint2d(oRB.MaxPoint.X, oRB.MinPoint.Y)
Set maxXmaxY = oTG.CreatePoint2d(oRB.MaxPoint.X, oRB.MaxPoint.Y)
this works fine here's the result:
What I am struggling with is adding the following textbox:
MAT'L: PL. 1/8" x 3 1/2" x 11 9/16"
STEEL 44W
ITEM: STPL264-2115-1
QTY: 2
DONE BY: A.R
here, I want this textbox to be proportionnal to the rangebox of the flatpattern:
 So Whatever the size of the part, I want the textbox to be positionned as shown (centered, above, font size proportionnal)
any ideas?
thanks in advance!
Sergio.D.Suárez
Hi, do you need something like this? this is in VBA
Sub oTextBox()
If partDef.FlatPattern Is Nothing Then partDef.Unfold
Dim osketch As PlanarSketch
For Each osketch In partflat.Sketches
osketch.Delete
Next
sk.Name = "CTS"
sk.Edit
Dim oRB As Box2d
Dim otext As String
otext = "MATL: PL. 1/8""" & "x 3 1/2""" & "x 11 9/16""" _
& vbLf & "STEEL 44W " _
& vbLf & "QTY: 2" _
& vbLf & "DONE By: A.R "
Dim oCentX As Double
oCentX = ((oRB.MaxPoint.X - oRB.MinPoint.X) / 2) - 1
Dim oCentY As Double
oCentY = (oRB.MaxPoint.Y) + 3
Dim oCenterPt As Point
Set CenterPt = oTG.CreatePoint(oCentX, oCentY, 0)
Dim oTextPt As Point2d
Set oTextPt = sk.ModelToSketchSpace(CenterPt)
'add the textbox
Dim oSketchText As TextBox
Set oSketchText = sk.TextBoxes.AddFitted(oTextPt, otext)
sk.ExitEdit
ThisApplication.ActiveDocument.Rebuild
End Sub
then the same in Ilogic
For Each osketch As PlanarSketch In partflat.Sketches
osketch.delete
Next
sk.Name = "CTS"
sk.Edit
Dim oRB As Box2d
Dim otext As String = "MATL: PL. 1/8""" & "x 3 1/2""" & "x 11 9/16""" _
		& vbLf & "QTY: 2" _
Dim oCentX As Double = ((oRB.MaxPoint.X - oRB.MinPoint.X)/2)-1
Dim oCentY As Double = (oRB.MaxPoint.Y)+3
CenterPt = oTG.CreatePoint(oCentX,oCentY,0)
'add the textbox
sk.ExitEdit
iLogicVb.UpdateWhenDone = True
 I hope help solve your problem, regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
