textbox.converttogeometry
simone.custodi
simone.custodi
hi, i am new to ilogic, i would like to convert the texts in my assembly sketches to geometry. Can you help me textbox.converttogeometry? thank you.
JhoelForshav
Hi @simone.custodi
To convert all text to geometry in sketches in the assembly document, try this 🙂
Dim oAsm As AssemblyDocument = ThisDoc.Document
For Each oSketch As PlanarSketch In oAsm.ComponentDefinition.Sketches
	For Each oTextBox As Inventor.TextBox In oSketch.TextBoxes
		oTextBox.ConvertToGeometry("dim")
	Next
Next
In this case I used the font "dim", you also have to optional arguments in the ConvertTextToGeometry.
UseBigFont and BigFont.
JhoelForshav
To also handle textboxes in subassemblies/parts within the assembly, try this rule 🙂
iLogicVb.UpdateWhenDone = True
	Next
Next
For Each oRefDoc As Document In oAsm.AllReferencedDocuments
	If oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count > 0
		Try
			For Each oSketch As PlanarSketch In oRefDoc.ComponentDefinition.Sketches
				Next
			Next
		Catch
			'For some reason the sketch couldn't be converted
		End Try
Next
simone.custodi
Thanks for the top answer, it works great but maybe I got the question wrong. I tried to get the ilogic rule to work on VBA, but it doesn't work. Now it brutally invokes the external rule but how can I translate from ilogic to vba? thank you so much. How can I learn these programming well? I have big confusion in my head: ilogic, vba, vb.net, c ++, c #, etc etc
JhoelForshav
Hi @simone.custodi
Since you mentioned iLogic in your original post I thought you wanted to code as an iLogic rule.
Try this as the VBA version 🙂
Sub ConvertAllText()
Set oAsm = ThisApplication.ActiveDocument
Dim oSketch As PlanarSketch
Dim oTextBox As TextBox
For Each oSketch In oAsm.ComponentDefinition.Sketches
    For Each oTextBox In oSketch.TextBoxes
        Call oTextBox.ConvertToGeometry("dim")
    Next
Next
Dim oRefDoc As Document
For Each oRefDoc In oAsm.AllReferencedDocuments
    If oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count > 0 Then
            For Each oSketch In oRefDoc.ComponentDefinition.Sketches
                Next
            Next
Next
End Sub
