Text position of linear drawing dimension
m_baczewski
m_baczewski
Hi, after changing the position of the linear dimension text, the dimension lines become dashed. How can I make them solid again? I wrote a short code for this and it looks like the one below:
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim point As Point2d
Dim point1 As Point2d
Dim oDimensions As DrawingDimensions
oDimensions = oSheet.DrawingDimensions
Dim oDimension As LinearGeneralDimension
oDimension = oDimensions.Item(12)
point = oTG.CreatePoint2d(25.71,14.2)
oDimension.Text.Origin = point
Image before the changes:
Image after the changes:
dalton98
oDimension.Style.LineType = LineTypeEnum.kContinuousLineType
Michael.Navara
I tested your code and I can't confirm this behavior. Everything works as expected.
The issue is not in code.
