Text.Origin.y won't work
shastu
Advisor Advisor
shastu
This should be simple.  See below code.  The text in the dimension is centered, but then I want to position the dimension based off of variable that I captured previously.  I tried using oDrawingDim.Text.origin = variable, but it doesn't do it.  In the example below I changed the variable to the value of 5 just to clarify.
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet
Dim oSheet As sheet
Set oSheet = oDoc.ActiveSheet
Dim oDrawingDim As DrawingDimension
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
For Each oDrawingDim In oSheet.drawingDimensions
If TypeOf oDrawingDim Is LinearGeneralDimension Or _
TypeOf oDrawingDim Is AngularGeneralDimension Then
Call oDrawingDim.CenterText
oDrawingDim.Text.origin.y = 5
Next
tyler.warner
Try this:
Reference example here (link)
Dim oSheet As Sheet
For Each oDrawingDim In oSheet.DrawingDimensions
		Dim oPosition As Point2d
		oPosition = oDrawingDim.Text.Origin
		oPosition.Y = 5
		oDrawingDim.Text.Origin = oPosition
Next
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
shastu
Thanks.
