Test is file is iPart or iAssembly
Rob67ert
Rob67ert
To test is a file is an iPart I use:
SyntaxEditor Code Snippet
Dim partDoc As PartDocument = ThisApplication.ActiveDocument
If partDoc.ComponentDefinition.IsiPartFactory Or partDoc.ComponentDefinition.IsiPartMember Then
    MessageBox.Show("This IS an iPart", "Title")
    Return 'do nothing
Else
MessageBox.Show("This is NOT an iPart", "Title")
But what do I need to check if it is an iPart or an iAssembly?
I like to run some iLogic on my files, but not on the iPart or iAssembly files.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
TONELLAL
Try this :
Dim
partDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
'...Assembly document
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
'...part document
Alain
Rob67ert
This wil not work.
It will also see the iPart factory part as a part and the iAssembly factory as a assembly.
Robert
Rob67ert
Found it:
'Part file
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject And oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    If oDoc.ComponentDefinition.IsiPartFactory Or oDoc.ComponentDefinition.IsiPartMember Then
        MessageBox.Show("This is a iPart", "iPart")
        Return
    MessageBox.Show("This ia a Part", "Part")
'Assembly file
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
    If oDoc.ComponentDefinition.IsiAssemblyFactory Or oDoc.ComponentDefinition.IsiAssemblyMember Then
        MessageBox.Show("Dit is een iAssembly", "Title")
        Return
    MessageBox.Show("Dit is een Assembly", "Title")
Robert
