Template open after Drawing resources update.
Jesper_S
Jesper_S
Hi.
Got a small issue.
Got this iLogic to update the Drawing Resources on my drawings.
Works fine and updates Everything.
The problem comes later, after running this code on a drawing, I can't start a new Drawing from the Template.
I get this error.
So the question is, How do I Close an Invisible Drawing?
'List of Variables
	Dim oDrawingDoc As Inventor.DrawingDocument
    Dim oSheetNumber As Integer
	Dim oActiveSheetNumber As Integer
	Dim oActiveSheetName As String
	Dim oSheet As Sheet
    Dim oSourceTitleBlockDef As TitleBlockDefinition
    Dim oNewTitleBlockDef As TitleBlockDefinition
'Selects this document
	oDrawingDoc = ThisApplication.ActiveDocument
'Checks if there is a Title Block on the Active Sheet
        If oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
		MessageBox.Show ("Please Insert a Title Block on this Sheet!")
		Exit Sub
'Gets the Name of the Active Sheet to Activate it at the end of the Code
	oActiveSheetName = ActiveSheet.Name
'Gets the Name of the Title Block Currently in the Drawing to Insert at the end of this code
    oSheet = oDrawingDoc.ActiveSheet
    If (oSheet.TitleBlock.Name = "Rithuvud") Then
        oTitleBlockName = "Rithuvud"
	 Else:
        MessageBox.Show ("This drawing has an unknown title block")
        Exit Sub
'Gets the Name of the Border Currently in the Drawing to Insert at the end of this code
Try
	 oBorderName = oSheet.Border.Name
Catch
	MessageBox.Show("No border exists", "Title")
	Exit Sub
End Try
'Deletes ALL of the Title Blocks Shown in the Drawing
For oSheetNumber = 1 To oDrawingDoc.Sheets.Count
        oDrawingDoc.Sheets(oSheetNumber).Activate
        If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
            oDrawingDoc.ActiveSheet.TitleBlock.Delete
    Next oSheetNumber
	'MessageBox.Show (oActiveSheetName & vbCr & oTitleBlockName)
	Dim oTitle As TitleBlockDefinition
	Dim oTitleBlock As TitleBlock
	For Each oTitle In oDrawingDoc.TitleBlockDefinitions
        If oTitle.IsReferenced = False Then
        oTitle.Delete
		Next
'Deletes ALL of the Borders Shown in the Drawing
        If Not oDrawingDoc.ActiveSheet.Border Is Nothing Then
            oDrawingDoc.ActiveSheet.Border.Delete
    Next oSheetNumber
'Clear drawing resources
If oCurrentPane = "Vault" Then
ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate
	'delete sheet formats
	Dim oDoc As DrawingDocument
	oDoc = ThisApplication.ActiveEditDocument
	Dim oPane As BrowserPane
	oPane = oDoc.BrowserPanes.ActivePane
	Dim oDocNode As BrowserNode
	oDocNode = oPane.TopNode
	Dim oDrawingResourceNode As BrowserNode
	oDrawingResourceNode = oDocNode.BrowserNodes.Item("Drawing Resources")
	Dim oTitleBlocksNode As BrowserNode
	oTitleBlocksNode = oDrawingResourceNode.BrowserNodes.Item("Sheet Formats")
	Dim oBordersNode As BrowserNode
	oBordersNode = oDrawingResourceNode.BrowserNodes.Item("Borders")
	Dim oTitleBlocks As BrowserNode
	oTitleBlocks = oDrawingResourceNode.BrowserNodes.Item("Title Blocks")
	Dim oNode As BrowserNode
	For Each oNode In oTitleBlocksNode.BrowserNodes'oDocNode.BrowserNodes
	' If the node is visible and expanded, collapse it.
	If oNode.Visible = True And oNode.Expanded = False Then
	oNode.Expanded = True
	Next
	For Each oNode In oBordersNode.BrowserNodes'oDocNode.BrowserNodes
	Next
	For Each oNode In oTitleBlocks.BrowserNodes'oDocNode.BrowserNodes
	Next
	Dim oSheetFormatNode As BrowserNode
	For Each oSheetFormatNode In oTitleBlocksNode.BrowserNodes
	' Select the node in the browser.
	oSheetFormatNode.DoSelect
	' Execute the delete command.
	ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute
	Next
	'Dim oBordersNode As BrowserNode
	For Each oBordersNode In oBordersNode.BrowserNodes
	oBordersNode.DoSelect
	Next
	For Each oTitleBlocks In oTitleBlocks.BrowserNodes
	oTitleBlocks.DoSelect
	Next
'Adds the Title Blocks from the Template File
ThisDrawing.ResourceFileName = "C:\_Vault_WS\Libraries\Templates\Standard.idw"
ThisDrawing.KeepExtraResources = True
'Add Borders
ActiveSheet.Border = "A1"
ActiveSheet.Border = "A2"
ActiveSheet.Border = "A3"
ActiveSheet.Border = "A4"
'Adds the Same Title Block as before
	ActiveSheet.TitleBlock = oTitleBlockName
	ActiveSheet.Border = oBorderName
    Next oSheetNumber
'Activates the Sheet by Full Name
ActiveSheet = ThisDrawing.Sheet(oActiveSheetName)
Thanks in advance.
//Jesper
WCrihfield
There are two tools for this situation, depending on if you still have access to the document object, or not.
You can use the following 'ReleaseReference' method for individual document situations, where the document is no longer being referenced by anything.
Document.ReleaseReference Method
Or you can use the CloseAll method to clean-up after dealing with a bunch of documents (like after a loop, or at the end of a rule).  It has an option that allows you to only close 'unreferenced' documents.
Documents.CloseAll Method
These are primarily used to release memory, for performance reasons.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Ralf_Krieg
Hello
You also try to close the document only.
For Each oDoc As Document In ThisApplication.Documents
	If oDoc.FullDocumentName = "C:\_Vault_WS\Libraries\Templates\Standard.idw" Then
		oDoc.Close(True)
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Jesper_S
Thanks alot.
That was a simple and fast way to solve my problem.
//Jesper
