Template 3D PDF edit
pklWNF89
pklWNF89
Hi guys.
I resently discovered the usefullness of 3D pdf's, so im trying to create my own template.
Is there a line of coding that allows me to get the properties of a selected part in an assembly
(Name, description, qty)?
-Patrick Lægg
laszlo_nagy
You'll need Acrobat (not Acrobat Reader)!  I think the best, if you open an existing template (by Autodesk, in the Templates folder) and modify it for your needs.
these templates have embedded javascripts, and I think is  better to modify it or extend it, than rewrite the whole thing from zero
these are the documentations what I've found so far
https://opensource.adobe.com/dc-acrobat-sdk-docs/acrobatsdk/pdfs/acrobatsdk_3djs.pdf
https://forums.autodesk.com/autodesk/attachments/autodesk/78/617294/2/6.Anark%20Core%20Static%20PDF%...
Ici, je connais un outil gratuit en ligne dans lequel vous pouvez convertir des pdf, y ajouter plusieurs images et fusionner pdf. Cet outil gratuit est d'éditer un pdf et de le rendre créatif. Vous devriez l'essayer une fois. Merci...... 😉
Moderator note: English translation added:
Here I know a free online tool in which you can convert pdf, add multiple images and merge pdf. This free tool is to edit pdf and make it creative. You should try it once. Thank you......
