Target Folder
Target Folder
CGVJM6DF
Target Folder
CGVJM6DF
I try to do an external rule, which will be used by different users.
How can I do this line:
Dim targetFolder As String
targetFolder = "C:\Users\Cgv\Documents"
Where "Cgv" it is me. But I want each user to have the file in their "Documents"
FINET_Laurent
Can you try this line and give us feedback ?
MsgBox(My.Computer.FileSystem.SpecialDirectories.MyDocuments)
Thank you and kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Jacob__with__a__k
@CGVJM6DF
to get the username from the Inventor Application options use this line:
myName = ThisApplication.GeneralOptions.UserName
to get the Username from the current Windows user: use code below
WSHnet = CreateObject("WScript.Network")
UserName = WSHnet.UserName
UserDomain = WSHnet.UserDomain
objUser = GetObject("WinNT://" & UserDomain & "/" & UserName & ",user")
'get user name
UserFullName = objUser.FullName
'remove space and replace with dot
oDotUserName = Replace(UserFullName," ",".")
'return both variations
MessageBox.Show( "Full User Name: " & vbCrLf & UserFullName & vbCrLf & oDotUserName, "iLogic")
and this works fine as well
it works fine when I test it, @FINET_Laurent, but not sure what will happen when you have multiple userfolders on the same pc
