Taking the roughest measurements in a view with C#
nebi_guler
Message 1 of 14
nebi_guler
I want to make the drawing in
ViewOrientationTypeEnum.kLeftViewOrientation
view as on the left, but it is almost impossible to scale correctly through the Curves in
DrawingCurves[(object)viewDimensions.ReferencedFile.Referenced Document as DrawingCurvesEnumerator]
Can you help me with this? My goal is to get certain measurements.
Replies (13)
Message 2 of 14
Michael.Navara
If the model is aligned to it's global coordinate system, you can use RangeBox from referenced model.
In this case you can create helper sketch in DrawingView, draw a line in them and create dimensions of this line.
Sub Main()
    Dim drawingView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Pick drawing view")
    Dim part As PartDocument = drawingView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim rangeBox As Box = part.ComponentDefinition.SurfaceBodies(1).RangeBox
    Dim minPointInSheetSpace As Point2d = drawingView.ModelToSheetSpace(rangeBox.MinPoint)
    Dim maxPointInSheetSpace As Point2d = drawingView.ModelToSheetSpace(rangeBox.MaxPoint)
    Dim drawingViewSketch As DrawingSketch = drawingView.Sketches.Add()
    Dim minPointInSketchSpace As Point2d = drawingViewSketch.SheetToSketchSpace(minPointInSheetSpace)
    Dim maxPointInSketchSpace As Point2d = drawingViewSketch.SheetToSketchSpace(maxPointInSheetSpace)
    drawingViewSketch.Edit()
    Dim diagonalLine as SketchLine = drawingViewSketch.SketchLines.AddByTwoPoints(minPointInSketchSpace, maxPointInSketchSpace)
    diagonalLine.SketchOnly = True
    drawingViewSketch.ExitEdit()
    Dim sheet As Sheet = drawingView.Parent
    Dim diagonalLineIntent = sheet.CreateGeometryIntent(diagonalLine)
    Dim textPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(drawingView.Position.X, drawingView.Position.Y - drawingView.Height / 2 - 1)
    Dim textPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(drawingView.Position.X + drawingView.Width / 2 + 1, drawingView.Position.Y)
    sheet.DrawingDimensions.GeneralDimensions.AddLinear(textPoint1, diagonalLineIntent, DimensionType := DimensionTypeEnum.kHorizontalDimensionType)
    sheet.DrawingDimensions.GeneralDimensions.AddLinear(textPoint2, diagonalLineIntent, DimensionType := DimensionTypeEnum.kVerticalDimensionType)
End Sub
Message 3 of 14
nebi_guler
I will try . And I will get back to you about it. Thank you . @Michael.Navara
Message 4 of 14
nebi_guler
part.ComponentDefinition.SurfaceBodies[1].RangeBox
this line comes empty.  I want to tell exactly @Michael.Navara
Message 5 of 14
Michael.Navara
Sorry I don't understand what happens. Can you upload a test model?
Message 6 of 14
nebi_guler
Of course @Michael.Navara
Message 7 of 14
Michael.Navara
I want the Inventor part model, but the screenshot explains a lot.
When you change type of variable part to AssemblyDocument, you need to update rest of your code to work with assemblies and its occurrences and so on.
Message 8 of 14
abdullah_elq
FYI @nebi_guler, at my last company we used DraftAid. Their add-in is really good at making these types of drawings.
Message 9 of 14
nebi_guler
I dont understand what do you mean " you need to update rest of your code to work with assemblies and its occurrences and so on." I have already written the code you wrote to me.
Message 10 of 14
Michael.Navara
Not exactly. Compare line 3 in my code and line 1027 in your. I declare variable part as PartDocument you declare variable part as AssemblyDocument.
I expect you want to create drawing from part not from assembly.
Message 11 of 14
nebi_guler
I will replace it and test it immediately
Message 12 of 14
nebi_guler
Message 13 of 14
yan.gauthier
Here's my code I use to get the bounding volume from a Part. The BoundingVolume is a simple custom class that contains the X,Y,Z dimensions with the Volume.
       public static BoundingVolume GetOrientedRangingBox(PartDocument partDocument)
           //assume partDocument exists
           var bodies = partDocument.ComponentDefinition.SurfaceBodies.Cast<SurfaceBody>();
           TransientBRep transientBRep = AddInServer.InvApp.TransientBRep;
           SurfaceBody? combinedBodies = null;
           if (bodies != null && bodies.FirstOrDefault() is SurfaceBody baseBody)
               combinedBodies = transientBRep.Copy(baseBody);
               if (bodies.Count() > 1)
                   foreach (SurfaceBody body in bodies.Skip(1))
                       if (body.IsSolid)
                           transientBRep.DoBoolean(combinedBodies, body, BooleanTypeEnum.kBooleanTypeUnion);
           if (combinedBodies is null) return new BoundingVolume(0, 0, 0);
           var orientedBox = combinedBodies.OrientedMinimumRangeBox;
           //Autodesk internal dimensions are always centimeter
           double[] dimensions = new double[] {orientedBox.DirectionOne.Length * 10, orientedBox.DirectionTwo.Length * 10, orientedBox.DirectionThree.Length * 10}.OrderByDescending(x => x).ToArray();
           return new BoundingVolume(dimensions[0], dimensions[1], dimensions[2]);
 This method cares not for your part to be aligned with the axis system.
Message 14 of 14
nebi_guler
Thank you i will try and check.
