Take model iProperties and place them in a sketch symbol as a prompted entry.
Hi All,
I am running inventor 2015 pro. I am attempting to call up certain iproperties of an assembly or part file presented in a view of an IDW using iLogic. I am using the script from the following thread as my starting point (iLogic copied below).
I would love to have a sketch symbol script in my IDW that pulls the iproperties from each view on a sheet and place them in the sketch symbol as the script already does for scale and view name. I would like to add the pulled iproperties as text below "scale". I hope I am just missing the syntax to pull the iproperties from the view and place them as a prompted entry.
If there is a more sensible way to do what I am asking I am all ears. I am having trouble overcoming the fact that I am frequently placing different views of multiple assemblies and parts on one page. Shortcuts that only look at the first view placed wont work, it will need to be view specific.
http://forums.autodesk.com/t5/inventor-customization/creating-intelligent-sketched-symbols/td-p/3313...
SyntaxEditor Code Snippet
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheets As Sheets
oSheets = oDoc.Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
'iterate through all of the sheets
For Each oSheet In oSheets
    'remove existing sketched symbols named View Label
    For Each oSymbol  In oSheet.SketchedSymbols
    If oSymbol.Definition.Name = "View_Label" Then
    oSymbol.Delete
    Else
    Next
'set sheet active
oSheet.Activate
'set a refernce to the drawing views collection
oViews = oDoc.ActiveSheet.DrawingViews
    ' Iterate through all of the views
    For Each oView In oViews
    'This places a sketched symbol with the name "View_Label"
    Dim oSymDef As SketchedSymbolDefinition
    'defind the sketch symbol to be inserted
    oSymDef = oDoc.SketchedSymbolDefinitions.Item("View_Label")
    'set a string array with values for the prompted entries found in the symbol
    Dim sPromptStrings(1) As String
    sPromptStrings(0) = "SCALE " & oView.Scale 'set to view scale
    sPromptStrings(1) = oView.Name 'set to view name
    sPromptStrings(2) = oView.iProperties.Value(doc, "Summary", "Subject") 'set to view name
    'set the position for the sketched symbol to be inserted
    ' and spaced off of the selected view center
    Dim oPosition As Point2d: oPosition = oView.Center
    oPosition.y = oPosition.y - (oView.Height / 2 + 0.6)
    'insert the sketched symbol and set the prompted entries
    oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings)
    Next
Next
'activate sheet1
oDoc.Sheets.Item(1).Activate
frederic.vandenplas
This should do what you're looking for
Dim oDocToGetProperties As Document
Set oDocToGetProperties = ThisApplication.Documents.Open(oView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName, "False")
Dim sPromptStrings(2) As String
sPromptStrings(2) = oDocToGetProperties.PropertySets.Item("Summary Information").Item("Subject").value 'set to view name
Call oDocToGetProperties.Close(True)
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
