Message 1 of 1
Table Driven ifeature Custom Parameter Does not Insert
Hi all,
I created a custom table driven ifeature, but when i insert the ifeature into a part it does not place the default value of the custom column. In this case seen in the image the custom column is CUT_LTH. When ever i insert the ifeature, the value which CUT_LTH is assigned is always the highlighted value seen in the image " 0.44 ".
If i remove the column as a custom property the ifeature inserts with the correct value, but i want to retain the ability to change the value.
Does anyone know a way to fix this issue?
