syntax error Sub Main() .... End sub
SpokenEarth
SpokenEarth
Hi, can anyone help me with this code? massage: 1.JPG
Sub CreateView()
    ' Set a reference to the drawing document.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'References this drawing sheet
    Dim oSheet As Inventor.Sheet
    oSheet = oDrawDoc.ActiveSheet
    ' Select a drawing view.
    Dim oDrawingView As DrawingView
    oDrawingView = ActiveSheet.View("A").View
    ' Ready code for creating of reference points
    Dim oTG As TransientGeometry
    oTG = ThisApplication.TransientGeometry
    ' Set a reference to the center of the base view.
    Dim oPoint As Point2d
    oPoint = oDrawingView.Center
    oPoint.X = oPoint.X + oDrawingView.Width
    Dim oCurveSeg As DrawingCurveSegment
    oCurveSeg = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick")
    Dim oCenterPoint As Point2d
    oCenterPoint = oCurveSeg.StartPoint
    ' Create the detail view.
    Dim oDetailView As DetailDrawingView
    oDetailView = oSheet.DrawingViews.AddDetailView(oDrawingView, oPoint, kFromBaseDrawingViewStyle, True, oCentrePoint, 1, , oDrawingView.Scale * 3, True, "Detail C")
End Sub
JhoelForshav
Hi @SpokenEarth
The main sub (where the code starts) in an ilogic rule has to be named "Main". So just change the line:
Sub CreateView()
To
Sub Main()
Or since you only have the one sub/function you can just delete the lines:
Sub CreateView() and End Sub
SpokenEarth
Silly me....Thank you
