Sweep Feature using sketches Profile and path
florian_wenzel
florian_wenzel
Inventor 2022  API with Visual Studio
i try to make a Sweep Feature with using existing sketches, path and Profile.
This is my Code:
Imports System.Runtime.InteropServices
Imports Inventor
Imports Microsoft.Win32
Module CommandFunctionButton_08
Public Sub CommandFunctionfweButton_08()
Dim oPartDoc As PartDocument = g_inventorApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oTO As TransientObjects = g_inventorApplication.TransientObjects
Dim oTG As TransientGeometry = g_inventorApplication.TransientGeometry
Dim oSketchLine1 As Object
oSketchLine1 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Select sketch line")
Dim oPathline As Path
oPathline = oCompDef.Features.CreatePath(oSketchLine1)
Dim oSectionSketch01 As Object
oSectionSketch01 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Select sketch Section")
Dim oProfile As Profile
oProfile = oSectionSketch01.Profiles.AddForSolid
Dim oSweep As SweepFeature
oSweep = oCompDef.Features.SweepFeatures.AddUsingPath(oProfile, oPathline, PartFeatureOperationEnum.kJoinOperation)
End Sub
End Module
What is wrong?
Thanks for any Suggestion.
Ralf_Krieg
Hello
I know, the API help contains an example using the AddUsingPath method, but this is not ducumented anywhere else. Can you try to create a SweepDefinition and use it, like described in this blogpost?
https://adndevblog.typepad.com/manufacturing/2015/10/create-a-sweepfeature-with-path.html
R. Krieg
RKW Solutions
www.rkw-solutions.com
florian_wenzel
no, this not the solution.
the error start befor going to Sweep Feature
The Sweep Definition is not the problem.
The selecting the sketches
CODE:
Imports Inventor
Dim oSweepDef As SweepDefinition
oSweepDef = oCompDef.Features.SweepFeatures.CreateSweepDefinition(SweepDefinitionTypeEnum.kPathAndGuideRailSweepDef, oProfile, oPathline, PartFeatureOperationEnum.kCutOperation)
Dim oSweepOne As SweepFeature
oSweepOne = oCompDef.Features.SweepFeatures.Add(oSweepDef)
End Sub
End Module
JelteDeJong
Try this iLogic rule:
Dim doc As PartDocument = ThisDoc.Document
Dim profile As Profile = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchProfileFilter, "Select profile")
Dim curve As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select sketch line")
Dim features = doc.ComponentDefinition.Features
Dim path As Path = features.CreatePath(curve)
Dim sweepFeatures = features.SweepFeatures
Dim sweepDefinition = sweepFeatures.CreateSweepDefinition(SweepTypeEnum.kPathSweepType, profile, path, PartFeatureOperationEnum.kNewBodyOperation)
sweepFeatures.Add(sweepDefinition)
Jelte de Jong
Blog: hjalte.nl - github.com
Ralf_Krieg
Hello
If you know where the code error's out, why don't you say it and post the error message?
We can not code a complete AddIn just to integrate and test your code.
The code to create a sweepdefinition is no correct too. SweepTypeDefEnum instead SweepTypeEnum, kCutOperation instead kJoinOperation - This can not work.
Thanks to @JelteDeJong pointing the pick method has  select filters for sketchprofiles/sketchcurves you need to use.
Anyway, try copy'n paste
Dim oSketchLine1 As Object= g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select sketch line")
Dim oPathline As Path = oCompDef.Features.CreatePath(oSketchLine1)
Dim oProfile As Profile= g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchProfileFilter, "Select sketch Section")
Dim oSweepDef As SweepDefinition = oCompDef.Features.SweepFeatures.CreateSweepDefinition(SweepTypeEnum.kPathSweepType , oProfile, oPathline, PartFeatureOperationEnum.kJoinOperation )
Dim oSweepOne As SweepFeature = oCompDef.Features.SweepFeatures.Add(oSweepDef)
End Sub
End Module
R. Krieg
RKW Solutions
florian_wenzel
yes!
PartFeatureOperationEnum.kCutOperation, copy past reason.
Thank you!
