Surfacetexturesymbol orientation
tobias_wiesendanger
tobias_wiesendanger
Anybody has an idea how to decide if a surfacetexturesymbol is on the left or on the right. I did not find any property that could help me check if it is on the left side or on the right side. Also why is the surfacetexturesymbol.Position in such a random position? (Those two circles mark it)
Maximilian_Bongartz
The key are the leadernotes.
When adding a surfaceTextureDefinition make sure, that the first Point is at the position of the text, and the second is on your geometry.
 Dim oCurve As DrawingCurve = THisApplication..CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick Curve")
 Dim oLeaderPoints As ObjectCollection = oInvApp.TransientObjects.CreateObjectCollection
 Dim oIntent As GeometryIntent = oSheet.CreateGeometryIntent(oCurve, PointIntentEnum.kMidPointIntent)
 Dim x1 As Double = oCurve.MidPoint.X
 Dim y1 As Double = oCurve.MidPoint.Y + 0.0000001
 oLeaderPoints.Add(oInvApp.TransientGeometry.CreatePoint2d(x1, y1))
 oLeaderPoints.Add(oIntent)
Dim oSurfaceTextureSymbolDefinition As SurfaceTextureSymbolDefinition = oSheet.SurfaceTextureSymbols.CreateDefinition()
Dim oSurfaceTextureSymbol As SurfaceTextureSymbol
oSurfaceTextureSymbol = oSheet.SurfaceTextureSymbols.AddByDefinition(LeaderPoints:=oLeaderPoints, SurfaceTextureSymbolDefinition:=oSurfaceTextureSymbolDefinition)
I only found a solution when creating. Flipping an existing Symbol is not possible so far (for me)
