So I'm not asking about iLogic this time. 😉
I received a stp file from a vendor and would like to create individual part files from the surfaces that were imported. I have tried different methods of importing, but I can't seem to import it as an assembly model. I either get one huge part file period, or I get a bunch of surfaces and still only one part file.
Not sure my explanation is clear. On the model tree under origin, I get a "filename".stp, when opened list about 500ish little 3d box icons each with a name. I can change properties of each to alter its appearance, but can't copy/paste it to a blank part file. it gives an option to "export object" but that doesn't seem to do anything helpful. It also gives option to "Copy to Construction" again with no apparent result. Also "Copy Object" doesn't seem to do anything helpful. In the past, I've created sketches on surfaces to create parts from this type of file, but I was hoping with Inventor 2017, there would be an easier option. Thanks in advance for any and all help.
Frank
Inventor 2017
