SURFACE IDENTIFICATION, GEOMETRY FORM AND CHANGE TYPE
HI,  im working in a program to mate a sphere to any kind of surface but i found a problem with the constraint command, when i try to mate the sphere with some parts of a surface the mate constraint does not recognize it, i think is the geometry form type because the constraint only works with the surfaces that are type 9.
i wonder if there is a way to chance the surface type or it would be great if someone could explain me what this numbers of geometry form mean
the next code returns the geometryform type in a message box.
Imports
System
Imports
System.Type
Imports
System.Activator
Imports
System.Runtime.InteropServices Imports
Inventor Imports
System.Math
Public
ClassForm1
Public _invApp As Inventor.Application
Dim _started AsBoolean
Dim boton AsBoolean
PublicSub ShowSaveAsDialog()
EndSub
PrivateSub add_clamp(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        InitializeComponent()
Try
            _invApp =
Marshal.GetActiveObject("Inventor.Application")
Catch ex AsException
Try
Dim invAppType AsType = _
                  GetTypeFromProgID(
                _invApp = CreateInstance(invAppType)
                _invApp.Visible =
True
                _started =
True
Catch ex2 AsException
                MsgBox(ex2.ToString())
                MsgBox(
"ERROR 001")
EndTry
EndTry
otravez:
Dim Superficie AsNewObject
        Superficie = _invApp.CommandManager.Pick(
SelectionFilterEnum.kAllEntitiesFilter, "Select point")
        MsgBox(
"superficie tipo: " & Superficie.geometryform.ToString)
GoTo otravez
EndSub
End
Class
philippe.leefsma
Hi
I have trouble understanding what you are talking about ... mate constraint can only be created between certain surface types. You can't just change a surface typw without changing the surface itself.
Please take a look at the AddMateConstraint method in the API Help Files:
Method that creates a new mate assembly constraint. The two input entities can be a combination of planar faces, linear edges, vertices, cylindrical faces, conical faces, spherical faces, revolved faces, work planes, work axes, and work points. When a cylindrical, conical, or revolved face is input, the axis of the surface is used for the constraint. When a sphere is input, the center point of the sphere is used for the constraint. To use the surface of a cylindrical, conical, or spherical face use the EntityOneInferredType or EntityTwoInferredType arguments.
I hope it helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thanks, actually I use the addmateconstraint method and when i used it i realize the problem that i can not mate the center of the sphere in some parts of the surface, and now i am placing the sphere manually near in the position of the surface that i need, so what i trying to do is find some way to do this with just on click in the surface.
thanks for your response
philippe.leefsma
So if I understand correctly, you now just want to run a command to insert the sphere on the surface? You can create a custom command that will prompt the user to select a surface and then run any logic want using the API...
Take a look at InteractionEvents Object in the help files, there are samples illustrating its use, for example "Basic Selection Using Interaction Events API Sample".
Hope this helps,
Philippe.
Philippe Leefsma
Ok, I haven't tried that topic in the help part, i going to check it out, as soon as I get a result i'll post it
Thanks!!
