Supressing pattern inside sub assembly
Charlies_3D_T
Charlies_3D_T
I need help with an ilogic rule where i want to supress a pattern inside a sub assembly. I can supres parts inside a sub asembly by just adressing them but i'm not able to adress the pattern. Anyone has an idea?
A.Acheson
Here is a post that deals with patterns. If you can insert the appropriate snippets at the correct level. Post the whole code if it isn’t working out.
https://forums.autodesk.com/t5/inventor-customization/ilogic-suppressing-the-element-2-of-a-pattern-...
Regards
Alan
Charlies_3D_T
@A.Acheson
Thank you for the link but the problem is that i'm not able to acces the sub assembly pattern inside the main assembly. I have for example a pâttern with name Pattern_Stairs and this pattern is just a pattern of parts. And i want this pattern to be suppressed inside a sub assembly. Do you have any hint how i can address this inside the main assembly?
