Suppressing a part occurrence based on an iProperty.
Hello Everyone,
So I am trying to build a custom 3rd party application for Inventor using the API. I have a utility class that does a lot of heavy lifting for me. I am trying to create a method that suppresses all other parts except the part with a specified iProperty value in the description.
In my code, I have been able to find the part with the particular iProperty value, but when I check the occurrences of that part in the assembly, the count is zero. Here is a snippet of the code I am using, is there anything I am doing wrong?
 public static void SuppressAllOccurancesExecpted(String iPropertyId, DocumentsEnumerator documents)
            foreach (Document document in documents)
                PropertySet propertySet = document.PropertySets["Design Tracking Properties"];
                Property description = null;
                PartDocument part = null;
                PartComponentDefinition partComp = null;
                ComponentOccurrences occurances = null;
                foreach (Property property in propertySet)
                    if(property.Name == "Description")
                        description = property;
                        if(description.Value == iPropertyId)
                            part = (PartDocument)document;
                            partComp = part.ComponentDefinition;
                            MessageBox.Show(part.DisplayName);
                            occurances = partComp.Occurrences;
                            MessageBox.Show(occurances.Count.ToString());
                        break;
Thank you very much for you assistance!
Michael.Navara
I don't know, what does it mean Occurrences in PartComponentDefinition, but what you are looking for is Occurrences in assembly context. This can't be obtained from part.
Dim asmDoc As AssemblyDocument
Dim asmDef = asmDoc.ComponentDefinition
For Each occ As ComponentOccurrence In asmDef.Occurrences
	Dim occDoc As Document = occ.Definition.Document
	If occDoc.PropertySets("Design Tracking Properties")("Description").Value = iPropertyId Then
		'Do something
	Else
		'Do something else
Next
shiftctrl.io
As mentioned, a Part document doesn't have occurrences, only Assembly documents do.  I've cleaned up your code a little by limited the scope of the variables, added a check to process only Assembly documents and switched the document itself from Part to Assembly.
Haven't tested it, but I think it will work.
	foreach (Document document in documents.Cast<Document>().Where(x => x.DocumentType == DocumentTypeEnum.kAssemblyDocumentObject))
			if (property.Name == "Description")
				var description = property;
				if (description.Value == iPropertyId)
					var assyDoc = (AssemblyDocument)document;
					var assyComp = assyDoc.ComponentDefinition;
					MessageBox.Show(assyDoc.DisplayName);
					var occurances = assyComp.Occurrences;
				break;
Thank you @Michael.Navara I was able to make the changes I want based on your code. I totally forgot I was suppose to use occurrences in an assembly
Thank you @shiftctrl.io your solution is more elegant
