I'm making a parametric part in sheet metal (Inventor 2019) and I want to switch between two different types of flanges. I've both made them and use a rule to suppress one flange and make the other one active.
I use the parameter "FLENSAFST" with two options "0" or "300". When the 300 is active it looks fine also when switching to 0 everything works like it should, but if I switch back to 300 I get an error in the extrustions because of a missing face. When using "Redefine" for the sketch it works again, but since it's a parametric part this isn't a solution for me.
The extrusion is nessecary and I'm only extruding the thickness, so this shouldn't be a problem.
Attached you can find the part, when opening the form you can click on "0" then choose apply and then switch back to "300". I hope someone can help me with this.
