Suppress Pattern Occurrence Element with Macro or API?
I need to be able to suppress individual elements of a circular pattern so I can retain the angular orientation while being able to reduce the number of instances.  I have found how to suppress the entire circular pattern, but can't seem to get the right terminology to access the elements one at a time.
The code I have to suppress the entire pattern is Feature.InventorFeature("Circular Pattern").Suppressed = True
Thanks.
Shane
Dim oPartDoc as PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oPattern As CircularPatternFeature
oPattern = oPartDoc.ComponentDefinition.Features.CircularPatternFeatures.Item(3)
oPattern.PatternElements.Item(4).Suppressed=True
oPartDoc.update
Drove me crazy, the code would run without any changes, then I noticed "Update" needed to be used.
This works.
Also found that you can access a feature by name for the same purpose.
oPattern1 = Feature.InventorFeature("Circular Pattern 1")
Then use a FOR loop to check if each element is suppressed or suppressed individual elements.
Works great!
