Suppress part features from assembly
Message 1 of 9
is it possible to suppress features that are in a part while they are in an assembly using ilogic? for example, i want to suppress a hole based on an embedded value in an assembly spreadsheet using the go.excel value in ilogic assembly. can i do this?
Replies (8)
Message 2 of 9
johnsonshiue
Hi! You could suppress the feature in the part at the assembly level.  However, the feature in the part will be suppressed. But, if you want two show the assembly with the feature suppressed and the feature unsuppressed at the same time, you will need to have two separate datasets. You cannot use one set of files to represent two geometric state. I guess you are attempting SWX's Configuration workflow in INV. For this particular case (suppressing/unsuppressing part feature), the closest workflow will be using iPart and iAssembly.
Many thanks!
Software Test Engineer
Message 3 of 9
thank you johnsonas long as i just have the part once in my assembly i can suppress/unsuppress features within that part? what would the ilogic code look like for that?
Message 4 of 9
johnsonshiue
Hi! Please share an example of what you have. Forum experts should be able to help craft the iLogic rule. It is not about how many occurrences of the part in the given assembly. It is about a part can only have one geometric definition at one time. You cannot have two geometric definitions of the same part (ipt file). iPart achieves it by using multiple member part files driven by the iPart factory.
Your example here will go a long way to avoid confusion and you can get your questions answered precisely.
Many thanks!
Message 5 of 9
that sounds great, johnson! thank you- Ii have attached the assembly and part.
this is the type of code im thinking? its currently in an ilogic rule in the assembly.
SyntaxEditor Code Snippet
HoleTest = GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "B1")
ExtrudeTest = GoExcel.CellValue("3rd Party:Embedding 1", "Sheet1", "B2")
' If HoleTest = "NO"
	' Suppress the hole feature from testpart
'Else If HoleTest = "YES"
	' Unsuppress the hole feature from testpart
' If ExtrudeTest = "NO"
	'Suppress the extrude feature from testpart
'Else If ExtrudeTest = "YES"
	' Unsuppress the extrude feature from testpart
InventorVb.DocumentUpdate(True)
thank you!
Message 6 of 9
Yijiang.Cai
@Anonymous, I am using Inventor 2019, and please see the attached files. I do not embed the excel file in the assembly, and just locate the excel file in the same location with Inventor file. Please see the code line, and hope it helpful for you.
Dim HoleTest As String
HoleTest=GoExcel.CellValue("Test.xlsx", "Sheet1", "B1")
Dim ExtrudeTest As String
ExtrudeTest = GoExcel.CellValue("Test.xlsx", "Sheet1", "B2")
If UCase(HoleTest) = "NO" Then
Feature.IsActive("testpart:1", "Hole1") = True
ElseIf UCase(HoleTest) = "YES" Then
Feature.IsActive("testpart:1", "Hole1") = False
If UCase(ExtrudeTest) = "NO" Then
Feature.IsActive("testpart:1", "Extrusion1") = True
ElseIf UCase(ExtrudeTest) = "YES" Then
Feature.IsActive("testpart:1", "Extrusion1") = False
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 7 of 9
JaneFan
Hi @Anonymous,
Not sure how you place your iPart file into assembly. If you place the iPart file into assembly as iLogic Component, then the code @Yijiang.Cai provided works well. Otherwise, if you simply place an iPart file as a common component, then we need control feature's suppression in another way:
Change River's code a little bit:
Dim oOcc As ComponentOccurrence
oOcc = ThisDoc.Document .ComponentDefinition.Occurrences.ItemByName("testpart-02:1")
Dim oSubDoc As PartDocument
If oOcc.IsiPartMember = False Then
		Feature.IsActive(oOcc.Name , "Hole1") = False
		Feature.IsActive(oOcc.Name, "Hole1") = True
		Feature.IsActive(oOcc.Name, "Extrusion2") = False
		Feature.IsActive(oOcc.Name, "Extrusion2") = True
Else
     oSubDoc = oOcc.ReferencedDocumentDescriptor.ReferencedDocument.ReferencedDocuments(1)
	 Dim oFeatures = oSubDoc.ComponentDefinition.Features
		oFeatures.HoleFeatures.Item("Hole1").Suppressed  = True
		oFeatures.HoleFeatures.Item("Hole1").Suppressed  = False
		oFeatures.extrudefeatures.item("Extrusion2").Suppressed = True
		oFeatures.extrudefeatures.Item("Extrusion2").Suppressed  = False
iLogicVb.UpdateWhenDone = True
Jane Fan
Inventor/Fusion QA Engineer
Message 8 of 9
that code worked wonderfully! thank you jane!
Message 9 of 9
iman.qx
Hi Jane
that is a very nice piece of code. thanks for sharing it.
I am having a problem, i thought you may have an idea to solve it. I create a code that makes a copy from an existing part in my assembly and place it in to the same assembly with the new parameters that user has put into the interface form. based on those parameter the part has be to updated meaning there is a rule in this part which suppress and unsuppress some features. when I call this rule in my code which is written in the subassembly right after the copy and place is done, I am facing an error! here I pasted the text of the error:
Error in rule: Suppress, in document: PP001_TT_Connection_Nozzle017.ipt
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
looks like inventor cannot copy and update feature suppression at the same time. I don't know if that is because the file is not open by inventor or not!
but if after copying I open the part manually and run the rule, everything works fine. I need to find a way to automate this procedure. that will be kind of you if you have any idea how to proceed with that.
thanks in advance
