Suppress messagebox
Suppress messagebox
jostroopers
Suppress messagebox
jostroopers
I have a part with two features.
If the location of feature 1 gets over the location of feature 2  I get a message box.
If I suppress feature 2  I want the message box does not appear.
How can I disable the message box as feature 2 suppressed.
Look in rule: Aansturen sparing.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
CCarreiras
HI!
Add the condition for Sparing 2  suppressed or not...
SyntaxEditor Code Snippet
If Feature.IsActive("Sparing2") = True Then
                'Melding als de locatie afstand van sparing 1 groter is dan sparing locatie 2.
                If SparingLocatie1 >= SparingLocatie2 Then
                MessageBox.Show("Let op afstand sparing 1 is groter dan sparing 2 ", "Afstand sparing")
                '�ls sparing locatie 1 is groter dan sparing locatie 2 word sparing 2 met 110mm voorbij sparing 1 geplaatst.
                    SparingLocatie2 = SparingLocatie1 + 110
CCarreiras
Owner2229
Hi, here is your rule "Aansturen sparing" a bit updated:
'Sparing type nummer aansturen afhankelijk van keuze.
Select Case Sparingtype
	Case "Sparing 1"
	Sparing_type_nr = 1
	Case "Sparing 2"
	Sparing_type_nr = 2
	Case Else
	Sparing_type_nr = 0
End Select
'Sparing aan of uit zetten afhankelijk van keuze.
If Sparing_type_nr = 1 Then
	Feature.IsActive("Sparing1") = True
	Feature.IsActive("Sparing2") = False
Else if Sparing_type_nr = 2 Then
Else if Sparing_type_nr = 0 Then
	Feature.IsActive("Sparing1") = False
'Áls sparing locatie 1 is groter dan sparing locatie 2 word sparing 2 met 110mm voorbij sparing 1 geplaatst.
Should work now
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
jostroopers
Thanks, Carlos and Mike.
This works for me.
Mvg Jos
