suppress little parts in assembly using traverse and VBA
harald.stratmann
harald.stratmann
Community Visitor
Community Visitor
I want suppress parts in an assembly which have dimensions less then a defined cube.
(Little parts to have a better performance)
I modified example traverse assembly
For each assembly in assembly i will create a levelofdetail
Problem is in procedure Sub processAllSubOcc
I try following code:
Private Sub cmdAktionStarten_Click()
    Dim detail As String
    Dim kl As Double
    If Me.txtDetailgenauigkeit.Value = "" Then
        MsgBox "Bitte einen Namen für die Detailgenauigkeit angeben!"
    Else
        If Me.txtKantenlänge.Value = "" Then
            MsgBox "Bitte einen Wert für die Kantenlänge angeben!"
        Else
            detail = Me.txtDetailgenauigkeit.Value
            kl = CDbl(Me.txtKantenlänge.Value)
            BaugruppeKleinteileUnterdrücken kl, detail
kl = length of cube  for e.g. 50 x 50 x 50 mm
detail = name level detail  for e.g. "Layout"
End Sub
Sub BaugruppeKleinteileUnterdrücken(Kantenlänge As Double, bez As String)
    Dim x As Double
    Dim y As Double
    Dim z As Double
    x = Kantenlänge
    y = Kantenlänge
    z = Kantenlänge
    ' Set reference to active document.
    ' This assumes the active document is an assembly
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get assembly component definition
    Dim oCompDef As Inventor.ComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    ErzeugeDetailgenauigkeit oCompDef, bez
    ' Get all occurrences from component definition for Assembly document
    Dim oCompOcc As ComponentOccurrence
    For Each oCompOcc In oCompDef.Occurrences
        If Not oCompOcc.Suppressed Then
        ' Check if it's child occurrence (leaf node)
        If oCompOcc.SubOccurrences.Count = 0 Then
            Set oCompDef = oCompOcc.Definition
            If BauteilUnterdrücken(oCompDef, x, y, z) = True Then
'Here it works fine
                oCompOcc.Suppress
        Else
            Call processAllSubOcc(oCompOcc, _
                                bez, _
                                x, _
                                y, _
                                z) ' subassembly
    Next
    oDoc.Rebuild
    oDoc.Update
    oDoc.Save
End Sub
Private Sub processAllSubOcc(ByVal oCompOcc As ComponentOccurrence, _
                             ByVal bez As String, _
                             ByVal x As Double, _
                             ByVal y As Double, _
                             ByVal z As Double)
    Dim oSubCompOcc As ComponentOccurrence
    Dim oSubCompDef As Inventor.ComponentDefinition
    If oCompOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            oCompOcc.SetLevelOfDetailRepresentation bez, True
    For Each oSubCompOcc In oCompOcc.SubOccurrences
        If Not oSubCompOcc.Suppressed Then
        Debug.Print oSubCompOcc.name
            If oSubCompOcc.SubOccurrences.Count = 0 Then
                Set oSubCompDef = oSubCompOcc.Definition
                If BauteilUnterdrücken(oSubCompDef, x, y, z) = True Then
' Here is the problem, after run suppress a new levelofdetail wil be created by system
' but the defined detail should be used
            Else
                Call processAllSubOcc(oSubCompOcc, _
                                bez, _
                                  x, _
                                  y, _
                                  z)
    Next
End Sub
Function BauteilUnterdrücken(bauteil As ComponentDefinition, x As Double, y As Double, z As Double) As Boolean
    'Dim oDoc As Object
    'Dim oCompDef As ComponentDefinition
    'Set oDoc = ThisApplication.ActiveDocument
    Dim ax As Double
    Dim ay As Double
    Dim aZ As Double
    'Set oCompDef = oDoc.ComponentDefinition
    ax = 10 * (bauteil.RangeBox.MaxPoint.x - bauteil.RangeBox.MinPoint.x)
    ay = 10 * (bauteil.RangeBox.MaxPoint.y - bauteil.RangeBox.MinPoint.y)
    aZ = 10 * (bauteil.RangeBox.MaxPoint.z - bauteil.RangeBox.MinPoint.z)
    If (ax < x) And (ay < y) And (aZ < z) Then
        BauteilUnterdrücken = True
    Else
        BauteilUnterdrücken = False
End Function
Sub ErzeugeDetailgenauigkeit(baugruppe As AssemblyComponentDefinition, bez As String)
    Dim DGVorhanden As Boolean
    DGVorhanden = False
    ' Create a new level of detail representation.
    ' The new representation is automatically activated.
    Dim oLODRep As LevelOfDetailRepresentation
    Dim oRM As RepresentationsManager
    Set oRM = baugruppe.RepresentationsManager
    Dim oLOD As LevelOfDetailRepresentation
    For Each oLOD In oRM.LevelOfDetailRepresentations
        If oLOD.name = bez Then
            DGVorhanden = True
        Else
            DGVorhanden = False
    Next
    If DGVorhanden = False Then
        Set oLOD = oRM.LevelOfDetailRepresentations.Add(bez)
        oRM.LevelOfDetailRepresentations.Item(bez).Activate (True)
    Else
        'Set oLOD = oRM.LevelOfDetailRepresentations.Item(bez)
End Sub
I hope somebody have a solution
Best regards
Harald
HermJan.Otterman
did you know about the selection filters in an Assembly?
in an Assy, Press shift+rightmouse
- first: select "Part Priority"
- Second: press again shift+rightmous, then select "component size"
after selecting all the small parts, you can do something with them...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
