Suppress Flat Pattern Feature using iLogic
Message 1 of 9
I have two features within my flat pattern (Extrusion1 & Extrusion2) and I'd like to be able to suppress one or the other using iLogic.
I came across this link, which is quite useful when wanting to suppress or unsuppress features as a group:
https://www.cadlinecommunity.co.uk/hc/en-us/articles/201893522-iLogic-for-Flat-Pattern-Features-in-I...
However I just want to do this on an individual basis
For example :
If hinge = 0 Then
Feature.IsActive("Extrusion1") = True
Feature.IsActive("Extrusion2") = False
ElseIf hinge = 1 Then
Feature.IsActive("Extrusion1") = False
Feature.IsActive("Extrusion2") = True
How would I change this to alter the flat pattern features instead?
Replies (8)
Message 2 of 9
Owner2229
Hi, maybe something like this?
' Get the document's definition
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oSMCD As SheetMetalComponentDefinition = oDoc.ComponentDefinition Dim oFlatFeatures As FlatPatternFeatures = oSMDef.FlatPattern.Features
' Get the hinge Dim Active1 As Boolean
If hinge = 0 Then
Active1 = True
Active1 = False
' Suppres features ("not" before "Active1" is negating it)
Try
oFlatFeatures.Item("Extrusion1").Suppresed = Not Active1
oFlatFeatures.Item("Extrusion2").Suppresed = Active1
Catch
End Try
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 9
Get the following error, sorry I'm not too good with code. What should I declare this as?
Error on Line 4 : 'oSMDef' is not declared. It may be inaccessible due to its protection level.
Message 4 of 9
Owner2229
Sorry, I made a misstake, try it now:
Dim oFlatFeatures As FlatPatternFeatures = oSMCD.FlatPattern.Features
' Get the hinge Dim Active1 As Boolean If hinge = 0 Then Active1 = True ElseIf hinge = 1 Then Active1 = False End If ' Suppres features ("not" before "Active1" is negating it) Try oFlatFeatures.Item("Extrusion1").Suppresed = Not Active1 oFlatFeatures.Item("Extrusion2").Suppresed = Active1 Catch End Try
Mike
Message 5 of 9
Gives this error:
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
Message 6 of 9
Owner2229
Well, it seems you can't use "Feature.IsActive" or ".Suppres" for FlatPattern features, so we have to add them to collections:
On Error Resume Next
' Create suppress collections:
' oColOne is for features UnSuppressed If "hinge = 0"
' oColTwo is for features Suppressed If "hinge = 0"
Dim oColOne As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim oColTwo As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
' Add features to collections
oColOne.Add(oFlatFeatures.Item("Extrusion1"))
oColTwo.Add(oFlatFeatures.Item("Extrusion2"))
' Get the hinge and suppress features
If hinge = 0 Then
    oSMCD.FlatPattern.UnSuppressFeatures(oColOne)
    oSMCD.FlatPattern.SuppressFeatures(oColTwo)
    oSMCD.FlatPattern.SuppressFeatures(oColOne)
    oSMCD.FlatPattern.UnSuppressFeatures(oColTwo)
Mike
Message 7 of 9
I had to change a couple of things to get it working. Line 1 of your code seemed to just be skipping the error with no effect.
This was the code I ended up arriving at:
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
oSMCD = oDoc.ComponentDefinition
oFlatFeatures = oSMCD.FlatPattern.Features
'Define all the features you want to work with
Dim oExtrudeFeature1 As ExtrudeFeature = oFlatFeatures.Item("Extrusion1")
Dim oExtrudeFeature2 As ExtrudeFeature = oFlatFeatures.Item("Extrusion2")
'Create object collection 1
'Create object collection 2
oColOne.Add(oExtrudeFeature1)
oColTwo.Add(oExtrudeFeature2)
Try
If Parameter ("hinge") = 0 Then
' Suppress collection 2 & UnSuppress collection 1
ElseIf Parameter ("hinge") = 1 Then
' UnSuppress collection 2 & Suppress collection 1
Catch
End Try
Message 8 of 9
wolfgang_nickl
Hello together,
I'm searching for another solution and studied your example.
It will work if you use Suppressed  instead of Suppresed:
' Get the hinge
If hinge = 0 Then
    Active1 = True
Active1 = False End If ' Suppres features ("not" before "Active1" is negating it) Try oFlatFeatures.Item("Extrusion1").Suppressed = Not Active1 oFlatFeatures.Item("Extrusion2").Suppressed = Active1 Catch End Try
Best Regards
Wolfgang
Message 9 of 9
klaashaesen
I have been trying to figure out how to disable features in the flat pattern for some time.
Finally I found this post. Your code does the trick.
