Suppress and unsuppress subassemblies based on conditions
Ahmed.shawkyXTZHN
Message 1 of 11
Ahmed.shawkyXTZHN
Hi everyone , how I can suppress and unsuppress subassemblies based on conditions through Ilogic or VB code , thanks.
Replies (10)
Message 2 of 11
Andrii_Humeniuk
Hi @Ahmed.shawkyXTZHN . This is a simple iLogic rule that suppresses all first-level subassembly. Describe how the rule should work, what the conditions should be, whether you need to add a message box with a question (suppress/unsuppress).
Dim oDoc As Document = ThisApplication.ActiveDocument
If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
Dim oAsmDoc As AssemblyDocument = oDoc
Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
For Each oOcc As ComponentOccurrence In oOccs
	If oOcc.DefinitionDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
	If Not oOcc.Suppressed Then oOcc.Suppress(True)
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 11
Ahmed.shawkyXTZHN
THANKS
Message 4 of 11
Ahmed.shawkyXTZHN
Hi @Andrii_Humeniuk  is it possible to suppress all parts that has certain name "INNER" with simple code instead of using the below method , thanks.
Message 5 of 11
Andrii_Humeniuk
Yes, it is not difficult. Here is the rule that Suppress and Unsuppress all first-level details with the word INNER in the name depending on the Double_SKIN parameter.
Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim bSKIN As Boolean
Try : oParam = oAsmDef.Parameters("Double_SKIN").Value
Catch : Exit Sub : End Try
Dim oOccs As ComponentOccurrences = oAsmDef.Occurrences
	If Not oOcc.Name.Contains("INNER") Then Continue For
	If bSKIN Then : oOcc.Unsuppress()
	Else : oOcc.Suppress(False)
Next
Message 6 of 11
Ahmed.shawkyXTZHN
thanks for your response , it works fine for parts in assembly but can it work for all levels for parts in sub assemblies as well  , also it's suppressing but once I tick double skin again it is kept suppressed although it require to unsuppress, thanks.
Message 7 of 11
Andrii_Humeniuk
Please try this code:
Sub main
	Call SuppressINNER(oAsmDef.Occurrences, "INNER", bSKIN)
End Sub
Private Function SuppressINNER(ByVal oOccs As ComponentOccurrences,
								ByVal sName As String,
								ByVal bSKIN As Boolean)
		If oOcc.DefinitionDocumentType <> kAssemblyDocumentObject Then
			If oOcc.SubOccurrences Is Nothing Then Continue For
			Dim oSubOccs As ComponentOccurrencesEnumerator = oOcc.SubOccurrences
			Dim iQTY As Integer = oSubOccs.Count
			If iQTY = 0 Then Continue For
			Call SuppressINNER(oSubOccs, sName, bSKIN)
		Else
			If Not oOcc.Name.Contains(sName) Then Continue For
	Next
End Function
Message 8 of 11
Ahmed.shawkyXTZHN
I received error on line 18 , Error on line 18 in rule: Rule8, in document: 00223807.iam
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Message 9 of 11
Andrii_Humeniuk
Because of my self-confidence, I didn't run tests after writing the code, so there were stupid errors. Now this code is working fine, please test it.
Sub main
	Try : bSKIN = oAsmDef.Parameters("Double_SKIN").Expression
End Sub
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
			If oOcc.SubOccurrences.Count = 0 Then Continue For
			Call SuppressINNER(oOcc.SubOccurrences, sName, bSKIN)
		Else
	Next
End Function
Message 10 of 11
Ahmed.shawkyXTZHN
thanks Andrii , I received error for line 23 for unsuppressing.
Message 11 of 11
Andrii_Humeniuk
I hope these changes help you. Please try this code:
Sub main
	Dim oInveApp As Inventor.Application = ThisApplication
	Dim oDoc As Document = oInveApp.ActiveDocument
	oDocs = oInveApp.Documents
	Dim oAsmDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
End Sub
Dim oDocs As Documents
Private Sub SuppressINNER(ByVal oOccs As ComponentOccurrences, ByVal sName As String, ByVal bSKIN As Boolean)
			Dim oRefDoc As AssemblyDocument = oDocs.Open(oOcc.Definition.Document.FullDocumentName, False)
			Call SuppressINNER(oRefDoc.ComponentDefinition.Occurrences, sName, bSKIN)
			Call oRefDoc.Close(True)
		Else
			Else
				Try : oOcc.Suppress(True)
				Catch : MessageBox.Show(oOcc.Name, "Don`t suppress") : End Try
	Next
End Sub
