Suppress all features starting with 02 or 03 etc. in a part
michael_janssenCN38L
We have an ilogic code that allows you to switch features back and forth with the suppression using the "low and high" parameters. This has worked wonderfully so far.
But I'm looking for a shorter way where I say: suppress all features that start with "03 - ".
Does anyone have a solution?
Attached is the current ilogic code
Dim part As PartDocument = ThisDoc.Document
Dim features As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
Features.Add(Feature.InventorFeature("Extrusion - polygon:1"))
Features.Add(Feature.InventorFeature("Rectangular Pattern - polyon:1"))
If Level:of:detail = "low" Then
	Dim featuresToSuppress = ThisApplication.TransientObjects.CreateObjectCollection()
	For Each f As PartFeature In features
		If Not f.Suppressed Then featuresToSuppress.Add(f)
	Next
	part.ComponentDefinition.SuppressFeatures(featuresToSuppress) 'NO Error
If Level:of:detail = "high" Then
	Dim featuresToUnsuppress = ThisApplication.TransientObjects.CreateObjectCollection()
		If f.Suppressed Then featuresToUnsuppress.Add(f)
	Next
	part.ComponentDefinition.UnsuppressFeatures(featuresToUnsuppress) ' NO Error
Where 2 feature suppressions now take place:
If possible, I would like to replace this with e.g.:
Features.Add(Feature.InventorFeature("03 - *.*"))
Michael.Navara
You can use LINQ expression for this. Sample below just prints the count and names of the features which starts with "03 - " to iLogic log window.
Dim nameStartsWith = "03 - "
Dim partFeatures As PartFeature() =
	part.ComponentDefinition.Features.OfType(Of PartFeature).Where(
		Function(partFeature) partFeature.Name.StartsWith(nameStartsWith)).ToArray()
'Do something with result
Logger.Debug(partFeatures.Count())
For Each PartFeature As PartFeature In partFeatures
	Logger.Debug(PartFeature.Name)
Next
Unfortunately, I don't get the connection. Unfortunately, my knowledge of Ilogic is too limited for that.
When I insert the code, I get the following error message:
Michael.Navara
This two code snippets are not compatible as is.
My code snippet shows how to select part features which name starts with "03 - " and put them to the variable partFeatures. Later on, you can do something with this array of features. For example print names to the log window (my sample) or convert the array to ObjectCollection and suppress/unsuppress this features.
The error you get because variable features is not declared and iLogic interprets it as type Inventor.Features.
Curtis_Waguespack
@michael_janssenCN38L , I think this might work for you, or at least give you a nudge in the right direction.
Hope that helps,
Curtis
Dim features02 As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
Dim features03 As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
For Each f As PartFeature In part.ComponentDefinition.Features
	If Left(f.Name, 4) = "02 -" Then features02.Add(f)
	If Left(f.Name, 4) = "03 -" Then features03.Add(f)
Next
For Each f As PartFeature In features02
	f.Suppressed = (Level:Of:detail = "low")
Next
For Each f As PartFeature In features03
	f.Suppressed = (Level:Of:detail = "high")
Next
