Suitable iLogic funtions for part template
CAD-One
CAD-One
Guys,
I am working on creating a new part file Template. Anybody has or can think of a useful and productive iLogic functions those are already available.
A while ago, I had seen one that would simply triger when part was checked in or saved. It would check if the material feild was utilzed or forgotten at Default.
On those lines, please share if there are any good iLogic functions that we might benefit from.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
You can use the following to check if the Material is set to Default and display a message box if it is.
If ThisDoc.Document.ComponentDefinition.Material.Name = "Default" Then
i = MessageBox.Show("Please Select a Material Type" & vbnewline & ThisDoc.PathAndFileName(True), "Title", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
I also use similar code to check for Part Number, Description, etc.
-Shawn
CAD-One
Thanks for responding & pointing to a good direction.
C1
AutoCAD 2020
