Substitute conventional structures to STD Frames
Hello Folks,
Greetings from Kiran
My question is , how to replace each members of this attached structure in STD frame members
1) What is optimum method
2) Is it possible to make cutouts ,extruxhions for STD frames
Please help me in this regards
Kiran Kori
adam.nagy
Autodesk Support
Autodesk Support
Hi Kori,
The frame generator has no API. What you might be able to do is check how to create what you need through the UI and then examine the parts created e.g. inside VBA: http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Then try to recreate the components programmatically.
Cheers,
Adam Nagy
Autodesk Platform Services
