Subspress Label of section View with iLogic
j_weber
Mentor Mentor
j_weber
Hallo everybody,
often I have only one section view in a drawing.
In this situation the DIN-Standard says that the section line and the label of the section view is not needed.
I found a code to switch the layer of the section line off.
But I didn't found something to subspress only the label off.
Is it possible to do this with iLogic. ?
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
WCrihfield
Try this:
Dim oSheet As Inventor.Sheet = ThisDrawing.Document.ActiveSheet
Dim oSView As SectionDrawingView
For Each oView As DrawingView In oSheet.DrawingViews
	If oView.ViewType = DrawingViewTypeEnum.kSectionDrawingViewType Then
		oSView = oView
		Exit For
Next
oSView.ShowLabel = False
'oSView.Label.Layer.Visible = False
Wesley Crihfield
(Not an Autodesk Employee)
j_weber
Great,
it works perfect.
Thanks a lot. It saves me a lot of steps that I usually must do.
Jörg Weber
j_weber
Sorry,
i forget to accept the answer.
Jörg Weber
