Sub-Assembly Selection Filter
brotherhogue
brotherhogue
Is it possible to set up a selection filter that ignores part-type components and only targets occurrences that are assemblies? kAssemblyLeafOccurrenceFilter and kAssemblyOccurrenceFilter aren't helpful. If this filter doesn't exist, can someone think of a workaround? I only want the user to be able to select assemblies.
WCrihfield
Hi @brotherhogue.  Since there is no variation of the SelectionFilterEnum for that specific request, it would likely require creating a whole special Class block of code, capable of 'handling' Inventor API Events, then start a selection session, rely on an event handler to 'react' to selection actions, and use your own internal selection filtering process within that event handler, to make it not possible to add those specific types of selections to the documents current SelectSet.  Long and complicated, but likely not impossible.
If you want to keep is simpler though, you could simply check the ComponentOccurrence that gets 'Picked', and if it does not meet your criteria, do not do anything with it, and/or continue letting them 'Pick' another/more.  Maybe, if using some sort of collection object, and adding the Picked ones into that collection for processing later, you could just not put the ones that do not meet your criteria into the collection.  Just throwing some ideas around
Are you familiar with the process of 'handling' Inventor API events?
Wesley Crihfield
(Not an Autodesk Employee)
