Sub Assemblies don't update representations with any code, only manually it seems.
cencinaNB2ET
cencinaNB2ET
With an assembly inside an assembly the colours are only updated if the representation is manually altered ( or just accessed via manual). I have tried looking for a way to do this with code but it does not seem to work.
Please see screen cast video that shows this in more detail.
Is this a bug?
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim Occurrences As ComponentOccurrences
Dim oAsmCompDef As AssemblyComponentDefinition
Dim oViewReps As DesignViewRepresentations
Dim oViewRep As DesignViewRepresentation
Dim oViewRepName As String
For Each oOcc In oAsmDef.Occurrences
If oOcc.DefinitionDocumentType = 12291 Then
oAsmCompDef = oOcc.Definition.Document.ComponentDefinition
oViewReps = oAsmCompDef.RepresentationsManager.DesignViewRepresentations
oViewRep = oAsmCompDef.RepresentationsManager.ActiveDesignViewRepresentation
oViewRepName = oViewRep.Name
MessageBox.Show(oOcc.Name & vbCr & oOcc.DefinitionDocumentType & vbCr & oViewRepName)
'oViewReps.Item(ViewRep).Activate
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").Activate
'oOcc.SetDesignViewRepresentation("Default", True)
Next
Andrii_Humeniuk
Hi @cencinaNB2ET . I made a small change to your code and added line 12 which removes the associativity. Please try it.
Dim oRepMan As RepresentationsManager
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		oOcc.IsAssociativeToDesignViewRepresentation = False
		oRepMan = oAsmCompDef.RepresentationsManager
		oViewReps = oRepMan.DesignViewRepresentations
		oViewRep = oRepMan.ActiveDesignViewRepresentation
		oViewReps.Item("Default").Activate
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
cencinaNB2ET
Yes I see it set them to Default, however I noticed I want them set to [Primary], this new option that appeared with the introduction of model states. Do you how to set them to that?
I tried the String "[Primary]" but it does not work.
Andrii_Humeniuk
Hi @cencinaNB2ET . I again changed the rule that read over all components of all levels. If you only need the top level, then comment out lines 21-23.
Sub main
	Call ChangeRepresent(oAsmDef.Occurrences)
	ThisApplication.ActiveView.Fit
End Sub
Private Function ChangeRepresent(oOccs As ComponentOccurrences)
	For Each oOcc As ComponentOccurrence  In oOccs
			Dim oAsmCompDef As AssemblyComponentDefinition = oOcc.Definition
			Dim oRepMan As RepresentationsManager = oAsmCompDef.RepresentationsManager
			Dim oViewReps As DesignViewRepresentations = oRepMan.DesignViewRepresentations
			Dim oViewRep As DesignViewRepresentation = oRepMan.ActiveDesignViewRepresentation
			Dim oViewRepName As String = oViewRep.Name
'			MessageBox.Show(oOcc.Name & vbCr & oOcc.DefinitionDocumentType & vbCr & oViewRepName)
			If oViewRepName <> "[Primary]" Then
				oViewReps.Item("[Primary]").Activate()
			If oOcc.SubOccurrences IsNot Nothing Then
				Call ChangeRepresent(oOcc.SubOccurrences)
	Next
End Function
