Stuck in Loop
Stuck in Loop
HogueOne
Stuck in Loop
HogueOne
can anybody help me learn why I'm getting stuck in a loop? I want the user to keep selecting an entity called "bottom curve" until they're satisfied with the selection, the press escape to continue with the code, but I keep getting stuck in a loop where it infinitely asks me to select a bottom curve even if I press escape around line 126. I could really use a hand...
Sub Main()
    Dim oAsmDoc As AssemblyDocument = GetActiveAssemblyDocument()
    If oAsmDoc Is Nothing Then Exit Sub
    Dim selectedFile As String = SelectFile()
    If selectedFile = "" Then Exit Sub
    Dim newFile As String = CreateCopyWithIncrementedName(selectedFile)
    If newFile = "" Then
        MessageBox.Show("Failed to create a copy of the file.", "Error")
        Exit Sub
    Dim oOccurrence As ComponentOccurrence = AddOccurrenceToAssembly(oAsmDoc, newFile)
    If oOccurrence Is Nothing Then Exit Sub
    oOccurrence.Adaptive = True
    Dim oPlane As Object = SelectPlane()
    If oPlane Is Nothing Then Exit Sub
    Dim oOccPlaneFront As WorkPlane = GetOccurrencePlane(oOccurrence, "PlaneFront")
    If oOccPlaneFront Is Nothing Then Exit Sub
    CreateFlushConstraint(oAsmDoc, oPlane, oOccurrence, oOccPlaneFront)
    Dim oSketchCurves() As Object = SelectSketchCurves()
    If oSketchCurves Is Nothing Then Exit Sub
    Dim oOccAxes() As WorkAxis = GetOccurrenceAxes(oOccurrence)
    If oOccAxes Is Nothing Then Exit Sub
    CreateMateConstraints(oAsmDoc, oSketchCurves, oOccurrence, oOccAxes)
    MessageBox.Show("Adaptive occurrence added and constrained successfully.", "Success")
End Sub
Function GetActiveAssemblyDocument() As AssemblyDocument
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    If oAsmDoc.DocumentType <> kAssemblyDocumentObject Then
        MessageBox.Show("Please open an assembly document.", "Error")
        Return Nothing
    Return oAsmDoc
End Function
Function SelectFile() As String
    Dim oFileDlg As Inventor.FileDialog = Nothing
    ThisApplication.CreateFileDialog(oFileDlg)
    oFileDlg.InitialDirectory = "C:\"
    oFileDlg.Filter = "Inventor Files (*.ipt; *.iam)|*.ipt; *.iam|All Files (*.*)|*.*"
    oFileDlg.DialogTitle = "Select a file to insert as an occurrence"
    oFileDlg.CancelError = True
    On Error Resume Next
    oFileDlg.ShowOpen()
    If Err.Number <> 0 Then
        MessageBox.Show("File selection canceled.", "Error")
        Return ""
    ElseIf oFileDlg.FileName = "" Then
        MessageBox.Show("No file selected.", "Error")
        Return ""
    On Error GoTo 0
    Return oFileDlg.FileName
End Function
Function AddOccurrenceToAssembly(oAsmDoc As AssemblyDocument, filePath As String) As ComponentOccurrence
    oOccurrence = oAsmDoc.ComponentDefinition.Occurrences.Add(filePath, ThisApplication.TransientGeometry.CreateMatrix())
        MessageBox.Show("Failed to add the selected file as an occurrence.", "Error")
    Return oOccurrence
End Function
Function SelectPlane() As Object
    oPlane = ThisApplication.CommandManager.Pick(kWorkPlaneFilter, "Select a plane in the assembly.")
        MessageBox.Show("No plane selected.", "Error")
    Return oPlane
End Function
Function GetOccurrencePlane(oOccurrence As ComponentOccurrence, planeName As String) As WorkPlane
    Dim oOccPlane As WorkPlane
    oOccPlane = oOccurrence.Definition.WorkPlanes.Item(planeName)
    On Error GoTo 0
    If oOccPlane Is Nothing Then
        MessageBox.Show("Geometric entity '" & planeName & "' cannot be found. Aborting operation.", "Error")
    Return oOccPlane
End Function
Sub CreateFlushConstraint(oAsmDoc As AssemblyDocument, oPlane As Object, oOccurrence As ComponentOccurrence, oOccPlane As WorkPlane)
    Dim oOccPlaneProxy As WorkPlaneProxy
    oOccurrence.CreateGeometryProxy(oOccPlane, oOccPlaneProxy)
    Dim oFlushConstraint As FlushConstraint
    oFlushConstraint = oAsmDoc.ComponentDefinition.Constraints.AddFlushConstraint(oPlane, oOccPlaneProxy, 0)
End Sub
Function SelectSketchCurves() As Object()
    Dim oSketchCurves(3) As Object
    Dim curveNames As String() = {"Bottom", "Top", "Left", "Right"}
    For i As Integer = 0 To 3
        ThisApplication.StatusBarText = "Select the " & curveNames(i) & " sketch curve"
        If i = 0 Then ' For the Bottom curve
            Dim lastSelectedCurve As Object = Nothing
            Do
                Try
                    Dim selectedCurve As Object = ThisApplication.CommandManager.Pick(kSketchCurveFilter, "Select the " & curveNames(i) & " sketch curve (Press Esc to finish)")
                    If selectedCurve IsNot Nothing Then
                        lastSelectedCurve = selectedCurve
                        MessageBox.Show("Bottom curve selected. You can select another curve or press Esc to finish.", "Selection")
                Catch ex As Exception
                    ' User pressed Esc
                    Exit Do
                End Try
            Loop While True ' Continue until Esc is pressed
            If lastSelectedCurve Is Nothing Then
                MessageBox.Show("No bottom curve was selected. Operation cannot continue.", "Error")
                Return Nothing
            Else
                oSketchCurves(i) = lastSelectedCurve
                MessageBox.Show("Bottom curve selection finished. The last selected curve will be used for the constraint.", "Selection Complete")
        Else ' For Top, Left, and Right curves
            Try
                oSketchCurves(i) = ThisApplication.CommandManager.Pick(kSketchCurveFilter, "Select the " & curveNames(i) & " sketch curve")
                If oSketchCurves(i) Is Nothing Then
                    MessageBox.Show("No sketch curve selected for the " & curveNames(i) & " constraint.", "Error")
                    Return Nothing
                Else
                    MessageBox.Show("Curve selected for " & curveNames(i) & ".", "Selection Complete")
                MessageBox.Show("Selection cancelled for " & curveNames(i) & " curve.", "Selection Cancelled")
                Return Nothing
            End Try
    Next
    Return oSketchCurves
End Function
Function GetOccurrenceAxes(oOccurrence As ComponentOccurrence) As WorkAxis()
    Dim oOccAxes(3) As WorkAxis
    Dim axisNames As String() = {"AxisBottom", "AxisTop", "AxisLeft", "AxisRight"}
        oOccAxes(i) = oOccurrence.Definition.WorkAxes.Item(axisNames(i))
        On Error GoTo 0
        If oOccAxes(i) Is Nothing Then
            MessageBox.Show("Geometric entity '" & axisNames(i) & "' cannot be found. Aborting operation.", "Error")
            Return Nothing
    Next
    Return oOccAxes
End Function
Sub CreateMateConstraints(oAsmDoc As AssemblyDocument, oSketchCurves() As Object, oOccurrence As ComponentOccurrence, oOccAxes() As WorkAxis)
    Dim oConstraints(3) As MateConstraint
        Dim oOccAxisProxy As WorkAxisProxy
        oOccurrence.CreateGeometryProxy(oOccAxes(i), oOccAxisProxy)
        oConstraints(i) = oAsmDoc.ComponentDefinition.Constraints.AddMateConstraint(oSketchCurves(i), oOccAxisProxy, 0)
    Next
End Sub
Function CreateCopyWithIncrementedName(originalFile As String) As String
    Dim fso As Object
    fso = CreateObject("Scripting.FileSystemObject")
    Dim folder As String = fso.GetParentFolderName(originalFile)
    Dim baseName As String = fso.GetBaseName(originalFile)
    Dim extension As String = fso.GetExtensionName(originalFile)
    Dim randomSuffix As String
    Do
        randomSuffix = GenerateRandomSuffix(8)
        newFile = folder & "\" & baseName & "-" & randomSuffix & "." & extension
    Loop While fso.FileExists(newFile)
    fso.CopyFile(originalFile, newFile)
    If fso.FileExists(newFile) Then
        Return newFile
    Else
        Return ""
End Function
Function GenerateRandomSuffix(length As Integer) As String
    Dim chars As String = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789"
    Dim random As New Random()
    Dim result As String = ""
    For i As Integer = 1 To length
        result &= Chars(random.Next(0, chars.Length))
    Next
    Return result
End Function
WCrihfield
There should always be something like:
If selectedCurve Is Nothing Then Exit Do
...if in a 'Do...Loop'.  Else, if in a While...End While, use 'Exit While'.  If in a 'For Each' or 'For i = 1 to' type loop, use 'Exit For'.  And so on, depending on the type of loop.
Wesley Crihfield
(Not an Autodesk Employee)
Frederick_Law
                    ' User pressed Esc
                    Exit Do
This catch exception, not ESC key.
Michael.Navara
As @WCrihfield mentions above you need to add Exit Do in your loop like this
Line120:
Do
	Try
		Else
			Exit Do
		' User pressed Esc
		Exit Do
	End Try
