String addresed to Sheetmetal material
didin.suryadi6JREK
didin.suryadi6JREK
Hello All
I am trying to make some simple i-logic, when we open the sheet metal part with an i-logic i want to have "inputbox" come up for material selection.
Please Help
JhoelForshav
Hi @didin.suryadi6JREK
Try this 🙂
Dim oDoc As PartDocument = ThisDoc.Document
Dim oActiveMaterial As String = oDoc.ActiveMaterial.DisplayName
Dim oMaterials As New List(Of String)
For Each oMaterial As MaterialAsset In ThisApplication.ActiveMaterialLibrary.MaterialAssets
	oMaterials.Add(oMaterial.DisplayName)
Next
If oMaterials.Contains(oActiveMaterial) = False Then oMaterials.Add(oActiveMaterial)
Dim selectedMaterial As String = InputListBox("Select material", oMaterials, oActiveMaterial)
oDoc.ActiveMaterial = ThisApplication.ActiveMaterialLibrary.MaterialAssets.Item(selectedMaterial)
didin.suryadi6JREK
Hellooo Jhoel
Thanks for the code, however it was works if i ran it on single ilogic, but when i combined it error msg with already declared object, tried to look up and delete the multiple string but did work, sorry.
Can you please review below code?
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp In oCustomPropertySet
'delete the custom iProperty
oCustProp.Delete
Next
Dim propertyName1 As String = "Rev Desc"
Dim propertyValue1 As String = ""
Dim customPropertySet As PropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
	prop = customPropertySet.Item(propertyName1)
Catch
	customPropertySet.Add("", propertyName1)
End Try
Dim propertyName2 As String = "Rev Date"
Dim propertyValue2 As Nullable(Of Date) = Date.Now
Dim NullDate As Nullable(Of Date)
Try
	prop = customPropertySet.Item(propertyName2)
Catch
	customPropertySet.Add(propertyValue2, propertyName2)
    iProperties.Value("Custom", propertyName2) = NullDate
End Try
Dim propertyName3 As String = "LaserProficient"
Dim propertyValue3 As String = InputBox ("Laser Proficient:","Set Property", "Yes")
Try
	prop = customPropertySet.Item(propertyName3)
Catch
	customPropertySet.Add(propertyValue3, propertyName3)
End Try
Dim propertyName4 As String = "ECN_DATE"
Dim propertyValue4 As Nullable(Of Date) = Date.Now
Try
	prop = customPropertySet.Item(propertyName4)
Catch
	customPropertySet.Add(propertyValue4, propertyName4)
	iProperties.Value("Custom", propertyName4) = NullDate
End Try
Dim propertyName5 As String = "ECN_ENGINEER"
Dim propertyValue5 As String = ""
Try
	prop = customPropertySet.Item(propertyName5)
Catch
	customPropertySet.Add(propertyValue5, propertyName5)
End Try
Dim propertyName6 As String = "ECN_NUMBER"
Dim propertyValue6 As String = ""
Try
	prop = customPropertySet.Item(propertyName6)
Catch
	customPropertySet.Add(propertyValue6, propertyName6)
End Try
Dim oUM As UnitsOfMeasure = oDoc.UnitsOfMeasure
Dim oLengthUnits As String = InputBox("Length units:", "Set Length Units", oUM.GetStringFromType(oUM.LengthUnits))
Try
	oUM.LengthUnits = oUM.GetTypeFromString(oLengthUnits)
Catch
	MessageBox.Show("""" & oLengthUnits & """"& " is not a valid length units", "Input Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Dim oMassUnits As String = InputBox("Mass units:", "Set Mass Unit", oUM.GetStringFromType(oUM.MassUnits))
Try
	oUM.MassUnits = oUM.GetTypeFromString(oMassUnits)
Catch
	MessageBox.Show("""" & oMassUnits & """"& " is not a valid mass units", "Input Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Try
Next
Dim selectedMaterial As String = InputListBox("Select material", oMaterials, oDoc.ActiveMaterial.DisplayName)
End Try
iProperties.Value("Summary", "Author") = ThisApplication.UserName
iProperties.Value("Project", "Revision Number") = InputBox("Revision Number:", "Set Property", "-")
iProperties.Value("Project", "Designer") = ThisApplication.UserName
iProperties.Value("Project", "Engineer") = ThisApplication.UserName
iProperties.Value("Project", "Creation Date") = Today
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
myMass = iProperties.Mass
MessageBox.Show("Mass = " & myMass, "iLogic")
JhoelForshav
Dim customPropertySet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
For Each oCustProp In customPropertySet
oCustProp.Delete
Next
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Next
Try
Catch
End Try
didin.suryadi6JREK
Hi Jhoel, Niceeit's works again,
Just little bit problem here, do you know how to sort (by name) the material list when the selection box come up?
it's taking time to look up on the irregular list and find the correct ones. Every seconds here is very influential and calculated, Sorry
JhoelForshav
oCustProp.Delete
Next
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Try
Catch
End Try
Next
oMaterials.Sort
Try
Catch
End Try
didin.suryadi6JREK
Really nicee,.. Thanks again and again
