Strange error
Strange error
Strange error
We've been using this rule quite a while. All of a sudden i get this error (attachment). The strange things are that;
- nothing has changed to the code,
- and only on my computer i get the error, my colleagues can run the same code on their computer without any problems (same Windows and Inventor version).
	aPath = ThisDoc.Path
	iPropParNum = iProperties.Value("Project", "Part Number")
	iPropRevNum = iProperties.Value("Project", "Revision Number")
	aFolder = aPath & "\" & "DWG"
	aDWG = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
	aDoc = ThisApplication.ActiveDocument
	transObjs = ThisApplication.TransientObjects
	aContext = transObjs.CreateTranslationContext
	aContext.Type = kFileBrowseIOMechanism
	aOptions = transObjs.CreateNameValueMap
	If aDWG.HasSaveCopyAsOptions(aDoc, aContext, aOptions) Then
	Dim aDataMedium As DataMedium
	aDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	aDataMedium.FileName = aFolder & "\" & iPropParNum & " rev" & iPropRevNum & " - 2D drawing" & ".dwg"
	aName = aDataMedium.FileName
	aDWG.SaveCopyAs(doc, context, options, oDataMedium)
	If System.IO.File.Exists( aFolder & "\" & " rev" & " - 2D drawing" & ".dwg" ) = True Then
	System.IO.File.Delete( aFolder & "\" & " rev" & " - 2D drawing" & ".dwg" )
	If System.IO.File.Exists( aFolder & "\" & iPropParNum & " rev" & " - 2D drawing" & ".dwg" ) = True Then
	System.IO.File.Move( aFolder & "\" & iPropParNum & " rev" & " - 2D drawing" & ".dwg", aFolder & "\" & iPropParNum & " - 2D drawing" & ".dwg" )
Does anybody know how this can be solved? Any help is welcome!
Stan
rossano_praderi
this is your code with few modifications (I cleaned up the code for my comfort), the error is generated by your code because you didn't check if the folder exist before exporting the file.
aFolder = aPath & "\DWG\"
If Not iPropParNum = "" Then
	If Not System.IO.Directory.Exists(aFolder) Then
		System.IO.Directory.CreateDirectory(aFolder)
	aName = aFolder & iPropParNum & " rev" & iPropRevNum & " - 2D drawing.dwg"
	aDataMedium.FileName = aName
'	If aDWG.HasSaveCopyAsOptions(aDoc, aContext, aOptions) Then
'	End If
	aDWG.SaveCopyAs(aDoc, aContext, aOptions, aDataMedium)
	If System.IO.File.Exists(aFolder & " rev - 2D drawing.dwg") = True Then
		System.IO.File.Delete(aFolder & " rev - 2D drawing.dwg")
	If System.IO.File.Exists(aFolder & iPropParNum & " rev - 2D drawing.dwg") = True Then
		System.IO.File.Move(aFolder & iPropParNum & " rev - 2D drawing.dwg", aFolder & iPropParNum & " - 2D drawing.dwg")
Best Regards
Rossano Praderi
IT Consultant and software developer
If my post answers your question, please click the ACCEPT SOLUTION button.
This helps everyone find answers more quickly!
Thank you, it works! Only one problem, it exports to a .zip file with fonts and the image used in my template, and i have no idea why it's doing that...
rossano_praderi
Hi, you have to setup your options through the inventor interface.
  1. Open a drawing document
  2. Use the SaveAsCopy command
  3. On the DialogBox select the file format "Autocad Dwg"
  4. Click on Options and make your settings
  5. Create the .INI file with your settings by using the save configuration buttom in the second DialogBox
  6. Now write full path and file name of your .INI in the follow code lines (right now in your code you will find the commented lines)
   strIniFile="NAME_OF_YOUR_INI_FILE.INI"
   oOptions.Value("Export_Acad_IniFile") = strIniFile
Best Regards
Rossano Praderi
Thank you, that worked!
