Strange doc.FullFileName
JoAntt
Message 1 of 10
JoAntt
Hi
In vb.net inventor 2018
I get this strange doc.FullFileName
"**C:\VaultWork\1.iam*LocalDocs*x0biyzm4fYmuvurkmP1tln1vqQd*A221033-MD-CHUTE-41L01_20210914.iam"
doc.DisplayName looks like this
Why is this happening?
Replies (9)
Message 2 of 10
WCrihfield
Hi @JoAntt.  It looks to me like you must be using Vault.  I am no expert in Vault right now, but I'm pretty sure that when you 'check out' a file to work on, it creates a temporary 'local' copy of the file.  Then when you are done working on the file, and go to 'check in' the file, it saves that local file back into the Vault area, then gets rid of the local copy.  I assume what you are seeing is the file location and file name of the temporary local copy of the file, while it is 'checked out'.  I know this is a fairly simplistic sounding explanation, but that is my guess/opinion about why you are seeing that odd looking file name.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 10
JoAntt
I dont think this i a vault thing.
I have narrowed it down to imported step files that is imported as reference model.
But now the question is, how can i detect and handle this type of files?
I cant find anything like ComponentDefinition.IsContentMember or type  for reference models.
Message 4 of 10
jjstr8
I'm not sure where the odd filename is coming from.  Vault doesn't use a temporary file that I'm aware of.  Checking out a file clears the read-only flag on the local file and changes its status on the Vault server.  @JoAntt :  Does doc.FullDocumentName return the same value?  The API documentation doesn't really explain the difference between FullFileName and FullDocumentName, but they've been equivalent every time I've seen during debugging.
Message 5 of 10
WCrihfield
Good theory @JoAntt.  I had not thought of that.  Here is a little bit of iLogic code for exploring any potentially 'imported' components in an assembly.  There are several ways of doing it though.
oADoc = ThisAssembly.Document
oADef = oADoc.ComponentDefinition
oOccs = oADef.Occurrences
For Each oOcc As ComponentOccurrence In oOccs
	If oOcc.IsAssociativelyImported Then
		MsgBox("The component named " & oOcc.Name & vbCrLf & _
		"is 'AssociativelyImported'.", , "")
		'oOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kForeignModelDocumentObject Or
		oOcc.DefinitionDocumentType = DocumentTypeEnum.kSATFileDocumentObject Then
		"Is either a 'Foreign Model' document, or a 'SAT' file document.",,"")
Next
oImpComps = oADef.ImportedComponents
For Each oIC As ImportedComponent In oImpComps
	MsgBox("The component named " & oIC.Name & vbCrLf & _
		"is an 'ImportedComponent'.",,"")
Next
Wesley Crihfield
Message 6 of 10
JoAntt
It presents itself as assembly document, not sat not anything else but assembly.
Nothing seams do be out of the ordinary except the FullDocumentName and FullFileName.
Message 7 of 10
jjstr8
If you're enumerating AllReferencedDocuments, it looks like you can check IsEmbeddedDocument to skip embedded imports.  Also, AssociativeForeignFilename has the full path to the original import file.  Neither property are in the API help, but they aren't hidden, so I assume they're somewhat safe to use long term.  I'm on 2019, but I'm guessing those properties are available in 2018.
Message 8 of 10
JoAntt
That seams to work! thank you!
Dim AssemblyDoc As AssemblyDocument = TheDoc ' Must be assembly
If AssemblyDoc.IsEmbeddedDocument = true Then
       msgbox("Its embedded!")
end if
Message 9 of 10
xAce20159
Community Visitor
Community Visitor
Hi @JoAntt @jjstr8 @WCrihfield is there any chance that I can access the correct FullDocumentName and FullFileName of the Imported Occurrence? This will be a big Help. Hoping for the positive response. Thank you
Message 10 of 10
WCrihfield
Hi @xAce20159.  Since this can be a complicated subject to look into, and there are several very similar sounding terminology, it would be best if you included a good screen captured image of what you are talking about.  It would also be very helpful if you fully described the manual steps you took to include that object into your assembly.  That will tell us more about what type of object it is, and how to look for it.  There are already some code examples above showing how to look into certain types of things labeled as 'imported' in an assembly, but we can certainly expand on those examples, or include new examples, if needed.
Below is another similar iLogic rule example for exploring similar stuff in an assembly, but it is designed to write its findings out into the iLogic Log window.  However, the iLogic Log window must already be visible before running this rule, or it will not be able to capture the feedback.  Then, after running it, check within the iLogic Log window for the results, if any.
Sub Main
	Dim oADoc As AssemblyDocument = TryCast(ThisDoc.Document, Inventor.AssemblyDocument)
	If oADoc Is Nothing Then Logger.Debug(iLogicVb.RuleName & " exited (no AssemblyDocument obtained)") : Return
	Dim oICs As ImportedComponents = oADoc.ComponentDefinition.ImportedComponents
	If oICs.Count > 0 Then
		For Each oIC As ImportedComponent In oICs
			Dim sFDN As String = String.Empty
			Try : sFDN = oIC.ReferencedDocumentDescriptor.FullDocumentName : Catch : End Try
			Logger.Info(vbCrLf & "FullDocumentName = " & sFDN & vbCrLf & _
			"IsLinkedToFile = " & oIC.LinkedToFile & vbCrLf & _
			"IsEmbedded = " & oIC.IsEmbedded & vbCrLf)
		Next oIC
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
		Dim sFDN, sFFN As String, bIsEmbedded, bIsLinked As Boolean
			sFFN = oOcc.AssociativeForeignFilename
			Logger.Info(vbCrLf & "Occurrence named " & oOcc.Name & vbCrLf & _
			"IsAssociativelyImported = True" & vbCrLf & _
			"AssociativeForeignFilename = " & sFFN & vbCrLf)
		ElseIf oOcc.HasAssociativeImportedComponent Then
			Dim oIC As ImportedComponent = oOcc.ImportedComponent
			"HasAssociativeImportedComponent = True" & vbCrLf & _
	Next oOcc
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
