STP Protocol Options
reg_58
Observer Observer
reg_58
Observer
Observer
I am trying to export to stp with the 242 protocol (Managed model based 3d engineering) however it just stays as automotive design. Below is my current code to export to stl, obj, stp and upload to vault. I have tried to change this number but have no luck. No matter the number it stays as automotive design
oOptions.Value("ApplicationProtocolType") = 3
I am also trying to get it to delete from vault if it exists before uploading. I have a check that returns true if it exists in vault but am having trouble deleting.
Any help would be much appreciated.
Sub Main()
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim fileFormats As String() = {"STL", "OBJ", "STEP" }
Dim exportPath As String = ThisDoc.Path
Dim ExportFileName As String = exportPath & "\"
For Each format As String In fileFormats
	Dim fullExportPath As String
		If Format = "STEP" Then
			fullExportPath = ExportFileName & iProperties.Value("Project", "Part Number") & ".stp"
		Else
			fullExportPath = ExportFileName & iProperties.Value("Project", "Part Number") & "." & Format.ToLower()
			        ' Export the file
        Dim oTranslatorAddin As TranslatorAddIn = Nothing
		oTranslatorAddin = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
		Else If Format = "OBJ" Then
			oTranslatorAddin = ThisApplication.ApplicationAddIns.ItemById("{F539FB09-FC01-4260-A429-1818B14D6BAC}")
		Else If Format = "STL" Then
			oTranslatorAddin = ThisApplication.ApplicationAddIns.ItemById("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
		Dim oContext As TranslationContext
		oContext = ThisApplication.TransientObjects.CreateTranslationContext
		Dim oOptions As NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	        ' Set translation options
		If oTranslatorAddin.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
			oOptions.Value("Resolution") = 0
			oContext.Type = kFileBrowseIOMechanism
		    Dim oData As DataMedium
		    oData = ThisApplication.TransientObjects.CreateDataMedium
			If Not Format = "STEP" Then
				oData.FileName = ThisDoc.ChangeExtension(Format.ToLower())
			Else
				oData.FileName = ThisDoc.ChangeExtension(".stp")
        ' Perform the export
		Try
			oTranslatorAddin.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
		Catch
			MsgBox("File export failed... It may exist", 64, "3D Exporter")
		End Try
	Dim mVltCon As VDF.Vault.Currency.Connections.Connection
	mVltCon = VB.ConnectionManager.Instance.Connection
	Dim folderPath As String = GetVaultFolderPath(exportPath)
	Dim folderId As Long = -1
	Dim folder As AWS.Folder = Nothing
	folder = mVltCon.WebServiceManager.DocumentService.GetFolderByPath(folderPath)
	        folderId = folder.Id
	Dim myFolder As VDFVault.Currency.Entities.Folder = New VDFVault.Currency.Entities.Folder(mVltCon, folder)
	Dim filePath As String = fullExportPath
	Dim myFileIterationNewFile As VDF.Vault.Currency.Entities.FileIteration = Nothing
	Using fileStream As Stream = New FileStream(filePath, FileMode.Open, FileAccess.Read)
	' Add the file to the vault
	CheckIfFileExistInVault(ExportFilename)
	Try
	myFileIterationNewFile = mVltCon.FileManager.AddFile(myFolder, System.IO.Path.GetFileName(filePath), System.IO.Path.GetFileName(filePath), DateTime.Now, Nothing, Nothing, Nothing, False, fileStream)
	Catch
		MsgBox(Format & " File exists in Vault. Delete and rerun rule or add manually", 64, "3D Exporter")
	End Try
	End Using
Next
End Sub
Function GetVaultFolderPath(localPath As String) As String
    ' Map local path to Vault path
    Dim baseLocalPath As String = "C:\$Vault\Designs"
    Dim baseVaultPath As String = "$/Designs"
    If localPath.StartsWith(baseLocalPath) Then
        Dim relativePath As String = localPath.Substring(baseLocalPath.Length).TrimStart("\"c)
        Return System.IO.Path.Combine(baseVaultPath, relativePath).Replace("\", "/")
    Else
        ' Handle cases where the path does not match the base path
        Throw New Exception("Local path does not match expected base path.")
End Function
Private Sub DeleteFileIfExists(filePath As String)
    If System.IO.File.Exists(filePath) Then
        Try
            My.Computer.FileSystem.DeleteFile(filePath, FileIO.UIOption.OnlyErrorDialogs, FileIO.RecycleOption.SendToRecycleBin)
        Catch ex As Exception
            MsgBox("Error deleting existing local file: " & ex.Message, 64, "3D Exporter")
        End Try
End Sub
Michael.Navara
For the STEP 242 use 5
From documentation:
STEPFileOptions ApplicationProtocolType
Integer value that indicates the application protocol type.
Valid values are: eAP203 = 2, eAP214IS = 4 and eAP242 = 5
Source here.
rtaylorD7A3L
Thank you, it works now.
Do you know how I can delete the previous version from vault. Sometimes it doesn't like to override these types of files. I have a check just before it tries to put it in vault that checks if it is already in vault. This returns a boolean in a function further down.
