Stop infinite loop without killing Inventor
mat_hijs
mat_hijs
Sometimes when you make a mistake in your code it ends up in an infinite loop. When an iLogic rule is running and does end up in an infinite loop, is there any way to stop this without having to kill the entire Inventor session with task manager?
Obviously the best way is to avoid infinite loops, but mistakes happen.
vpeuvion
You can add a counter that would allow you to exit the loop after exceeding a certain value for example.
look this : Résolu : Stop an iLogic rule while it's running - Autodesk Community - Inventor
Vincent.
Frederick_Law
Run debug in Visual Studio.
https://modthemachine.typepad.com/my_weblog/2019/12/using-visual-studio-to-debug-ilogic-rules.html
It works with IV2023 and VS Community 2022.
