Can you give a little more exlanation of what needs to start? is it the add in has something run or it will not work and will between some timeframe?
I need to copy some files at a specific time but only while Inventor is running so I need the addin to run when both those conditions are met but I don't want the addin to run in the backgroung all the time.
I think that it should be very easy to do this if you use a COM application (exe) and run it from the windows Scheduled Tasks. With this you can set the time and it will not run unless inventor is running if done like my sample shown.
Imports Inventor Module InventorRun Dim oApp As Application = Nothing Sub Main() Try oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") ' if we make it this far then we can say that Inventor is running 'Call to copy the files CopyFiles() Catch ex As Exception End Try 'clean up If Not oApp Is Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(oApp) oApp = Nothing End If End Sub Public Sub CopyFiles() 'add your code to copy the files here.. MsgBox("Copy Files") End Sub End Module
