Standalone Application Inventor
nicolas_couallier
nicolas_couallier
Good Morning,
i am trying to create an executable that launches Inventor, draws a few lines on a sketch and then save the part it created.
I wrote the following code in VBA using  Visual Studio 2019.
The code compile but when launched i have the following Exception: System.InvalidOperationException
The error is the public member 'TransientGeomtry' of 'PartDocument' type can be founded:
(in french below)
The code i wrote is the following:
Public Sub Triangle()
Dim oTG As TransientGeometry
Dim oDoc As PartDocument
oDoc = _invApp.Documents.Add(DocumentTypeEnum.kPartDocumentObject, _invApp.GetTemplateFile(DocumentTypeEnum.kPartDocumentObject))
Dim oSketch As PlanarSketch
oSketch = oDoc.ComponentDefinition.Sketches.Add(oDoc.ComponentDefinition.WorkPlanes.Item(3))
oTG = oDoc.TransientGeometry
Dim ocord(0 To 3) As Point2d
ocord(1) = oTG.CreatePoint2d(0, 0)
ocord(2) = oTG.CreatePoint2d(1, 0)
ocord(3) = oTG.CreatePoint2d(1, 1)
Dim oLines(0 To 4) As SketchLine
oLines(1) = oSketch.SketchLines.AddByTwoPoints(ocord(1), ocord(2))
oLines(2) = oSketch.SketchLines.AddByTwoPoints(ocord(2), ocord(3))
oLines(3) = oSketch.SketchLines.AddByTwoPoints(oLines(2).EndSketchPoint, oLines(1).StartSketchPoint)
I made the following Import:
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Inventor
Does anyone know where the problem comes from ?
Thank you for your answers.
FINET_Laurent
Salut !
It is in the application and not in the document that you have to look for the geometries.
C'est dans l'appication et non dans le document que tu dois aller chercher les géométries.
oTg = ThisApplication.TransientGeometry
et non oTg = oDoc.TransientGeometry
Bàt,
FINET L.
Mod note: English translation added
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
nicolas_couallier
It works perfectly.
Thank you very much.
